Thread started 27 Mar 2011 (Sunday) 00:46
question about my flash settings
Paul-R
Mar 27, 2011 00:46 |  #1
i have a rebel xs and almost done with completing my set up but i have one quick question .
K now under "flash control" "external flash func. setting" and the "E-TTL II" option gives you 2 setting options which are " evalutive" and "average" which one should i pick ?
thanks in advance .:lol:
apersson850
Obviously it's a good thing
Gallery: 35 photos
Mar 27, 2011 01:17 |  #2
Depends on the subject you're trying to take photos of. There's a lot to read about this, especially here.
Basically, evaluative metering applies a complex algorithm to measure the balance between ambient and flash light. It tries to determine which parts of the image are so far away that the flash can't reach them, which parts are so close that they'll get overexposed by the flash, which parts may be so reflective (window, mirror) that they blow out completely and what distance setting the lens has, since that's probably how far away your main subject is.
Average, on the other hand, computes an average flash exposure, without considering all these details.
Some claim that you should use evaluative outdoors and average indoors. Personally, I use evaluative all the time, unless my experience tells me that in a particular case, average will perform better.
Only you can acquire your experience, by trying it out. A thousand flash exposures from now you'll be better at it.
Anders
Paul-R
Mar 27, 2011 01:23 |  #3
thanks allot really appreciate the good help from this forum .
watt100
Mar 27, 2011 13:33 |  #4
Paul-R wrote in post #12100701 (external link)
also see the lighting and flash section. I also use evaluative but probably should experiment and if average is better for some situations
743 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is vinceisvisual
1239 guests, 176 members online
