Thread started 27 Mar 2011 (Sunday) 16:09
Lightning tips : Snowboard/skiing
tomme
Mar 27, 2011 16:09 |  #1
A friend of my asked if i could do some pictures of him while he is railing.. gonna do it tomorrow and it will be pretty dark outside.
Any tips on how to set up the flashes, do some backlit shoots? give me some ideas please :D
What i got:
two flashes + two umbrellas with stands and wireless trigger for it ( have a snoot and some gel for the flash also ).
5D + 35L + 135L, can also borrow a 50D + 10-20mm sigma lense so i can get real close and have a wide DOF.
Instagram (external link)
babymilo
Mar 27, 2011 21:23 |  #2
tomme wrote in post #12103967 (external link)
What i got:
I don't think soft light is really important, so you may not want to bother with the umbrellas
If it's dark, make sure you have enough light to get the focussing right at least, especially with the 5D.
Bud,
Bernard J. Lee Photography (external link) (under construction) | Gear List (external link)
Stuperfox
Gallery: 12 photos
Mar 27, 2011 22:37 |  #3
Power and short flash duration are what is needed. So you need 2-4 flashes set to half or 1/4th power to keep the power and lower the flash duration. Remember, you can bump up ISO to increase the power from the flash.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
anlenke
Joined Mar 2011
Mar 27, 2011 23:09 as a reply to  @ Stuperfox's post |  #4
A few things to think about:
Depending on the size of the railing, you may be able to get multiple pops on the rail (though you'll likely want to focus on one). Also, weight may be a consideration, depending on how far you'll have to travel to get to the shoot. The hard light looks good on snowboarding photos usually, so umbrellas aren't really "necessary", but I'd bring them if you can.
If you have a flash that can zoom, get in close, and leave it as wide as possible. If the rail itself is kinked (bent), or is especially interesting, then you'll probably want to light it as well. I really like being able to backlight the snow if it's falling, and it can look really cool to hit your friend with a backlight a stop or two higher than the mainlight, but you run the risk of flashing back right into your photo if you mistime it. No risk, no reward :cool:
Give me one minute, I'll draw what I mean :)
Hi. I'm Anton.
Personal work: Flickr (external link)
Gear, for those who want to know.
anlenke
Joined Mar 2011
Mar 27, 2011 23:19 as a reply to  @ anlenke's post |  #5
I agree, keep the ISO up so the image is still clean (400 ISO on a 5D should be fine), and that will allow you a lower power on the speedlites, for a faster duration, and they'll last a little longer (especially in the cold).
Setups like this could work well. Also, surf flickr for a few minutes and see...people have some awesome jibbing photos online.
Below is a quick example for a possible strong backlit example.
Hi. I'm Anton.
dmward
Gallery: 29 photos
Mar 27, 2011 23:51 |  #6
On a 5D, at ISO 800 1/16 power on a speedlite is going to mean the light is relatively close to the subject. The 1/4 backlight will essentially blow the highlights.
The distance scale on the back of a Speedlite shows the range of acceptable exposure given the camera settings for ISO, and f stop. Use that information to help you position the lights and the power settings.
tomme
Mar 28, 2011 11:56 as a reply to  @ dmward's post |  #7
thanks for the tips everyone! It will just be a little session in a backyard behind a grocery store. He will bring with him a rail, dont know how it looks though.. Also forgot to say i got a lightmeter so that will help alot, and the flashes are a 430exII and a YN460.
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Mar 28, 2011 12:01 |  #8
Use Anlenke's diagram as a starting point. You are going to need one light in front for illumination, and one from behind for background separation. Since they are different power lights you will have to mess around with them a bit to get a pleasing ratio.
tomme
Mar 28, 2011 12:51 as a reply to  @ gonzogolf's post |  #9
^will start with that option, if i set the flash ( 430exII ) at 1/16 and then i use the lightmeter to meter the other flash to two stops darker then the 430exII. Should i set the zoom for wide on the 430 ? like 28-35mm ?
gonzogolf
Gallery: 559 photos
Mar 28, 2011 12:59 |  #10
tomme wrote in post #12109658 (external link)
It depends on what you want illuminated. If you just want a rimlight and your timing is good you can aim it at the back of the skier and zoom in a bit more. If you want some of the snow and surrounding area lit up, or you want some extra latitude for timing zoom a bit wider.
tomme
Mar 28, 2011 13:08 as a reply to  @ gonzogolf's post |  #11
great tip, have some ideas hope they will work :)! Have been snowing ALOT today 20cm - 30cm and it still is snowing, but not that much. hope it stops soon though... 3 hours to the shooting, gonna be fun and a good experience to do this! havent done much strobist outside before :)
CiM_Photography
Joined Sep 2009
Mar 28, 2011 13:16 |  #12
BE SURE TO POST YOUR RESULTS!
Sorry for the caps - not yelling - just emphasizing.
Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer (external link) | Gear List>
tomme
Mar 28, 2011 14:09 as a reply to  @ CiM_Photography's post |  #13
^Will do ;)
tomme
Mar 28, 2011 17:31 as a reply to  @ tomme's post |  #14
The session is over :p .. it only lasted 30-40min because it was late and some people got angry because of the noise we made, hehe. They had to make there own speed for the rail so they did get a little tired after a while so i didn't get to many shots, but i did get some good ones ( will upload them on the mac soon and do some PP )!
My brother wasn't home so i couldn't borrow his 50D and lense, had a little problem with focusing with the 5D and the 135L so i had to manual override it sometimes.
And i missed the fast fps of the 50D BUT it was fun :)
Thanks for the info guys, will post the pictures as soon as im done..
tomme
Mar 28, 2011 18:37 as a reply to  @ tomme's post |  #15
here is one for ya :D
3,501 views & 0 likes for this thread, 12 members have posted to it.
475 guests, 158 members online
