Howdy,
I tried searching but couldn't find anything similar with what I'm trying to do. Will I be able to set up the 430EX II as master and 580EX II as slave using the 430EX II as fill light on camera?
Thanks!
pilipinophotography Member 157 posts Joined Oct 2010 More info | Mar 28, 2011 12:47 | #1 Howdy, Canon 5DMII & 60D
musashi Senior Member 795 posts Joined Jul 2010 Location: Winchester, CA / San Diego, CA / North Hollywood, CA More info | Mar 28, 2011 12:48 | #2 the 430 ex ii cant be a master. you could try doing it the other way around. “You can easily judge the character of a man by how he treats those who can do nothing for him.” --==Gear List & Feedback==--
gonzogolf dumb remark memorialized More info | Mar 28, 2011 12:49 | #3 No, the 430exII will not work as a master. The 580exII will master the 430 however.
Mar 28, 2011 12:53 | #4 Thanks for the quick response guys! The shoe on the 580 is loose when I mount it on camera and doesn't fire consistently. Off camera and remote, it works fine. Instead of paying to get it serviced, I wanted to see if I should just use the money on a 430 instead. Decisions decisions... Canon 5DMII & 60D
gonzogolf dumb remark memorialized More info | Mar 28, 2011 12:55 | #5 pilipino photography wrote in post #12109672 Thanks for the quick response guys! The shoe on the 580 is loose when I mount it on camera and doesn't fire consistently. Off camera and remote, it works fine. Instead of paying to get it serviced, I wanted to see if I should just use the money on a 430 instead. Decisions decisions... You could pick up an ST-E2, or a used canon 550ex or 580ex. Both of the older models can master the canon wireless system.
Mar 28, 2011 13:02 | #6 gonzogolf wrote in post #12109689 You could pick up an ST-E2, or a used canon 550ex or 580ex. Both of the older models can master the canon wireless system. I've got a deal in place for a brand new 430EX II for $250 cash. If I went that route, I'd just need to pick up a 2nd receiver for my existing wireless system and probably just mount the 430EX II on another tripod and place it next to me for fill flash? Then again, it'd probably make more sense to just grab a cheaper Yongnuo if I went that route. Canon 5DMII & 60D
gonzogolf dumb remark memorialized More info | Mar 28, 2011 13:04 | #7 pilipino photography wrote in post #12109761 I've got a deal in place for a brand new 430EX II for $250 cash. If I went that route, I'd just need to pick up a 2nd receiver for my existing wireless system and probably just mount the 430EX II on another tripod and place it next to me for fill flash? Then again, it'd probably make more sense to just grab a cheaper Yongnuo if I went that route. ![]() Yeah the primary reason to buy the canon flashes is for ettl work or to use in their wireless system. Otherwise lots more bang for the buck in aftermarket flashes.
apersson850 Obviously it's a good thing More info | But the flash foot spare part and replace it yourself, then, to save on that expense. Then you can use the 580 EX II as a master. Anders
Dekun Senior Member 315 posts Joined Jun 2010 More info | Speaking of Yongnuo, it just announced the YN-565EX flash, which promised the ETTL master capability. I think we can count on Yongnuo making it cheaper even than the 430EX II? It won't be widely available for a while though. 6D | 30D | Powershot S5 | 10-22 f/3.5-4.5 | Tamron 17-50 non-VC | 24-105 f/4L IS | 50 f/1.8 | 85 f/1.8 | 100 f/2.8L Macro IS | 580EX II | Cactus V5
Mar 29, 2011 01:12 | #10 apersson850 wrote in post #12112572 But the flash foot spare part and replace it yourself, then, to save on that expense. Then you can use the 580 EX II as a master. Or just fix the foot to the flash, if that's the issue. The 580 EX II has a metal foot, so it's not likely that it's worn out yet. I found the shimworld diy fix https://shimworld.wordpress.com …ite-580ex-ii-hotshoe-fix/ Canon 5DMII & 60D
Mar 29, 2011 01:17 | #11 Dekun wrote in post #12113452 Speaking of Yongnuo, it just announced the YN-565EX flash, which promised the ETTL master capability. I think we can count on Yongnuo making it cheaper even than the 430EX II? It won't be widely available for a while though. yes! pretty exciting news! looking forward to it. Canon 5DMII & 60D
gonzogolf dumb remark memorialized More info | Mar 29, 2011 08:35 | #12 pilipino photography wrote in post #12114229 I found the shimworld diy fix https://shimworld.wordpress.com …ite-580ex-ii-hotshoe-fix/ i had to order the damn screw driver cuz i couldn't find it any of my local shops here. i should get it on friday. i'm pretty sure it's just loose and i have a feeling it's due to the fong collapsible i've been using. Fong products are evil in that regard. There are much better options.
Mar 29, 2011 10:45 | #13 Yes, I wish I did more research on it prior asking for it for Christmas. My friend swore by it and just took his word. I'll probably put it on craigslist and grab a lumiquest diffuser instead. Canon 5DMII & 60D
BlurrCube ...a lucky id-iot that didn't get electrocuted... 15,147 posts Likes: 91 Joined Aug 2010 Location: Southern California More info | Mar 29, 2011 12:17 | #14 pilipino photography wrote in post #12114229 I found the shimworld diy fix https://shimworld.wordpress.com …ite-580ex-ii-hotshoe-fix/ i had to order the damn screw driver cuz i couldn't find it any of my local shops here. i should get it on friday. i'm pretty sure it's just loose and i have a feeling it's due to the fong collapsible i've been using. Hmm... my 430EX II has randomly exhibited some of these symptoms (gross overexposure, losing contact with camera). Unlocking and reseating the flash quickly solves this. I miss shots though since I don't always CHIMP. | Canon EOS Systems |
| Latest registered member was a spammer, and banned as such! 2725 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
