Thread started 28 Mar 2011 (Monday) 14:40
Question for Einstein 640 with Photoflex LiteDome
kn_guy87
Joined May 2003
Mar 28, 2011 14:40 |  #1
I got 2 Photoflex LiteDome Q39 Medium size and 2 Q39 Large size softboxes.
I am about to buy 4 Einstein 640s.
Do I buy this Photoflex speed ring?
http://www.bhphotovide​o.com …_Ring_Octo_Conn​ector.html (external link)
Or Can I use this?
http://www.bhphotovide​o.com …ick_Ring_with_S​wivel.html (external link)
With this
http://www.bhphotovide​o.com …peed_Ring_for_B​alcar.html (external link)
Thank you,
Ken
bobbyz
Mar 28, 2011 14:42 |  #2
Both setups should work.
Fuji XT-1, 18-55mm
Marloon
Mar 28, 2011 14:44 |  #3
Awesome Buy! I personally use the Bowens QuickRing with the SP studio systems Balcar Mount. You pay a bit more compared to the photflex Ring BUT you save TONS of time. After using the Bowens Quickring, you'll never go back to older more archaic speed rings.
Oh and another advantage to the Bowens Quickring is that if you were buying into another system (Elinchrom, Profoto, etc.), you can just buy the insert and you're golden!
I'm MARLON
Former Canon Platinum CPS member
5DII • 24L • 35L • 50L • 85L • 135L • 200LIS
Wordpress Blog (external link)Youtube Channel (external link)Twitter (external link)Gear List (external link)
kn_guy87
Joined May 2003
Mar 28, 2011 15:05 |  #4
Thank you both for quick reply.
I will surely buy the Bowens Quick Ring then.
bobbyz
Mar 28, 2011 15:31 |  #5
kn_guy87 wrote in post #12110673 (external link)
I need to buy that ring also. Currently I use photoflex speedring and putting those rods on 5' octa is pain. Last time I bent one the rods. I hear from Dave (tetrode) that newer photoflex rods are easier to bend.
Fuji XT-1, 18-55mm
kn_guy87
Joined May 2003
Mar 28, 2011 15:35 |  #6
Should I buy the grids for my Photoflex LiteDome?
How often do you use the grids?
tetrode
I am a walking repository of thoroughly useless information
Mar 28, 2011 15:57 |  #7
bobbyz wrote in post #12110882 (external link)
Ah, yes, I'm having a 5-foot Photoflex octa flashback. The original aluminum rods were nearly impossible to bend. At least bend the right way. I also managed to fatally deform one. Replacements for the original style rods are no longer available. Photoflex now supplies more conventional rods that are, indeed, easier to flex:
IMAGE: http://farm5.static.flickr.com/4135/4800905044_8e4afbcac2_o.jpg
Dave F.
bobbyz
Mar 28, 2011 16:17 |  #8
Dave,
any idea where to order these?
Fuji XT-1, 18-55mm
kn_guy87
Joined May 2003
Mar 28, 2011 16:39 |  #9
bobbyz wrote in post #12111223 (external link)
Dave,
Is this the one?
http://www.bhphotovide​o.com …Dome3_Softbox_M​edium.html (external link)
AlanU
Gallery: 144 photos
Mar 28, 2011 16:51 |  #10
using a bowens quickring you can use that with an octa. Its so easy to open up a 5foot octa....its ridiculously easy. The quick ring works with a softbox but you must drill out the two threaded holes for an octa.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
tetrode
Mar 28, 2011 17:59 |  #11
Dave,
Order what, Bobby? After I pretzel'ed one of my 5' octa's original rods and discovered I couldn't get an exact replacement, I decided to just replace all of the rods in the octa with the new type. I ordered them directly from Photoflex as they were not available (at the time) from B&H. If you click on "Replacement Parts" now on the Photoflex site, you'll be asked if you want to see new products, not replacement parts. Maddening!
If you're attached to the older style, virtually unbendable aluminum rods, I still have mine (used them as plant stakes) and I'd be happy to pass them on to you.
Dave F.
tetrode
Mar 28, 2011 18:00 |  #12
AlanU wrote in post #12111459 (external link)
It's actually just the 1/4-20 hole that needs to be drilled out, Alan.
Dave F.
bobbyz
Mar 28, 2011 20:59 |  #13
tetrode wrote in post #12111868 (external link)
Dave F.
That is what I meant the replacement rods for the octa as I didn't see them on B&H web site. Maybe I will order from Photoflex as they close to me here in CA.
Fuji XT-1, 18-55mm
bobbyz
Mar 28, 2011 21:01 |  #14
tetrode wrote in post #12111878 (external link)
Dave F.
That is what prevented me from buying the quickring as I am not DIY kind of guy. But lately I have installed a dishwasher along with a garbage disposal for the wifey so should be able to handle this quick ring mod.
Fuji XT-1, 18-55mm
Marloon
Mar 29, 2011 03:36 |  #15
Dave F.
Good point. Alan and I drilled out both holes on our quickrings. Hmmm next time I'll just drill out the 1/4-20 hole. Thanks for the tip Dave!
I'm MARLON
5,394 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is slipper1963
1525 guests, 170 members online
