Thread started 28 Mar 2011 (Monday) 19:27
First atempt at Butterfly lighting
Jamesino
Mar 28, 2011 19:27 |  #1
A reflector at the bottom would have probably gotten rid of the shadow from the chin on the neck. Single BD with 580. Thoughts?
IMAGE: http://i.imgur.com/ZEeUB.jpg
jeromego
Mar 28, 2011 20:45 |  #2
cant see the shadow under the nose.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
bobbyz
Mar 28, 2011 20:53 |  #3
Like Jerome said, where is the butterfly?
Fuji XT-1, 18-55mm
Jamesino
Mar 28, 2011 22:18 |  #4
Does this mean that my light has to be higher up?
windpig
Chopped liver
Mar 28, 2011 22:26 |  #5
Jamesino wrote in post #12113418 (external link)
Yes, or move it closer, but keep the same height.
Go ahead, spin the wheel.
dave63
Mar 28, 2011 22:37 |  #6
Jamesino wrote in post #12112349 (external link)
Thoughts?
Bears a vague resemblance to a young Melissa Etheridge.
windpig
Chopped liver
Mar 28, 2011 22:40 |  #7
dave63 wrote in post #12113520 (external link)
Yea, that's an amazing resemblance.
TMR ­ Design
Joined Feb 2006
Mar 28, 2011 23:08 as a reply to  @ windpig's post |  #8
Your light source needs to be closer to the subject and then the height is adjusted visually by looking at the shadow under the nose. If you're using Speedlight's and have no modeling light then pop off a few test shots at different heights to see where you're getting the most pleasing shadow.
If you have a reflector or a second light source then you can bring it in from below and create clam shell lighting to lift some shadow but the position and formation of the shadow stays the same.
Clam shell also falls into the category of Beauty lighting.
Robert
bobbyz
Mar 29, 2011 08:32 |  #9
I would also shoot from a higher angle. And the crop is too tight IMHO.
Fuji XT-1, 18-55mm
2,468 views & 0 likes for this thread, 6 members have posted to it.
2725 guests, 150 members online
