I just received a pair of them today and tested them. No miss fire, however, I have a question.
If you're using ETTL on Av mode, no way to sync up > 1/200s ? Sorry, I am really new to flash light world.
ddong Senior Member 405 posts Joined Dec 2008 More info | Mar 28, 2011 21:15 | #1 I just received a pair of them today and tested them. No miss fire, however, I have a question.
BrandonSi Nevermind.. I'm silly. More info | Mar 28, 2011 21:39 | #2 Flash fact #6*: Every SLR camera with a mechanical shutter has a maximum flash sync shutter speed (1/200 or 1/250 on current Canon DSLRs). This has to do with the way focal plane shutters work. At slower shutter speeds, the first curtain opens, the flash fires, and after the specified time duration, the second curtain closes behind it. At shutter speeds faster than flash sync, the second curtain begins to close before the first curtain is completely open. The second curtain follows the first across the frame, exposing only a slice of the image at any given moment. Firing a flash during this process would illuminate only part of the image. You may find the entire Flash 101 post worth reviewing, there is some good information there if you're just getting started.
klr.b Goldmember 2,509 posts Joined Jun 2009 Location: SoCal More info | Mar 29, 2011 03:22 | #3 ddong wrote in post #12113051 I just received a pair of them today and tested them. No miss fire, however, I have a question. If you're using ETTL on Av mode, no way to sync up > 1/200s ? Sorry, I am really new to flash light world. The Pixel triggers can do HSS, so you can sync to whatever your max is (1/8000s or 1/4000s depending on which camera you use). If you have a specific shutter speed in mind then set the camera to M and set it. When you're in Av the camera sets the SS. gordon
CiM_Photography Goldmember 1,813 posts Joined Sep 2009 Location: North Andover, MA More info | Mar 29, 2011 09:27 | #4 Or go into your menu and turn off the safety shift for your shutter speed. Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer
m.shalaby Goldmember 3,443 posts Likes: 8 Joined Dec 2009 More info | i had them and they fired off no matter what SS i was at 1/80, all the way up to 1/8000
CiM_Photography Goldmember 1,813 posts Joined Sep 2009 Location: North Andover, MA More info | Mar 29, 2011 09:43 | #6 Is that a bad thing, though? Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Mar 29, 2011 09:53 | #7 CiM_Photography wrote in post #12115963 Is that a bad thing, though? Only if you want to freeze action with the flash. If not, then it doesn't matter. ...Leo
Mar 29, 2011 10:03 | #8 WOW, thanks guys. POTN is POTN. These info definitely help.
m.shalaby Goldmember 3,443 posts Likes: 8 Joined Dec 2009 More info | Mar 29, 2011 10:04 | #9 CiM_Photography wrote in post #12115963 Is that a bad thing, though? HSS just cuts power from you flash via burst
| Latest registered member is Niagara Wedding Photographer 1320 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
