I am looking for a gel to turn my Canon 580EX flash into a match for tungsten lighting. I was told to look at "CTO gels". But a search turns up several. Which one is recommended? More precisely which strength? Thanks.
JChin Senior Member 415 posts Likes: 1 Joined Jul 2004 Location: New York City More info | Mar 29, 2011 04:48 | #1 I am looking for a gel to turn my Canon 580EX flash into a match for tungsten lighting. I was told to look at "CTO gels". But a search turns up several. Which one is recommended? More precisely which strength? Thanks. Johnny J. Chin ~ J. Chin Photography
LBaldwin Goldmember 4,490 posts Likes: 4 Joined Mar 2006 Location: San Jose,CA More info | Mar 29, 2011 04:58 | #2 To do this correctly you need a color meter. One that can tell exactly what the color temperature is of a given source. Rarely do you find a single matched source. Most often you will find mixed light sources, ie some tungston from household lamps, some flourescent, and some daylight coming in through the window. Les Baldwin
Mar 29, 2011 06:12 | #3 So I assume converting my flash (assumed "daylight") to tungsten (indoor lights at a restaurant-type environment), I would use a CTO. Right? Johnny J. Chin ~ J. Chin Photography
GJim Goldmember More info | Mar 29, 2011 07:31 | #4 You can order an entire pack of gel-modifiers using this link: G'Jim c):{- ... 2x 50D (Both Gripped), 2x 7D (Both Gripped), 2x 5D Mk II (One gripped), 1x 60D, assorted glass (10-800mm), sundry accoutrements.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 29, 2011 07:38 | #5 JChin wrote in post #12115040 So I assume converting my flash (assumed "daylight") to tungsten (indoor lights at a restaurant-type environment), I would use a CTO. Right? Can I take 2 half-CTO and stack them to make a full-CTO gel? Is that how it works? I was thinking of getting a full sheet and cutting it to size, if I can stack them for when I need more color. Am I thinking correctly? You're on the right track, but you will either need a colorimeter to determine the actual color of the lights or do some experimentation. Not all lights that you would think may be tungsten lights actually are. Skip Douglas
spkerer Senior Member 953 posts Likes: 31 Joined Mar 2008 Location: Leesburg, VA USA More info | Mar 29, 2011 07:52 | #6 LBaldwin wrote in post #12114884 If you are shooting digital you can color correct in camera, in post as well as pre shoot, your choice. Not always. If you're mixing flash and ambient in your exposure, you cannot color correct in camera or in post IF your flash in un-gelled (daylight) and the ambient is tungsten. If you're using your flash to overpower the ambient light, then yes you can color correct that. If it's mixed, you can color correct for either the flash or ambient, but not both. Mixed lighting like that is when you really want to use a gel so you have a single color temp in your photograph. Leesburg, Virginia
MarkyRB Mostly Lurking 18 posts Joined Jan 2011 More info | Mar 29, 2011 08:02 | #7 spkerer wrote in post #12115333 Not always. If you're mixing flash and ambient in your exposure, you cannot color correct in camera or in post IF your flash in un-gelled (daylight) and the ambient is tungsten. If you're using your flash to overpower the ambient light, then yes you can color correct that. If it's mixed, you can color correct for either the flash or ambient, but not both. Mixed lighting like that is when you really want to use a gel so you have a single color temp in your photograph. With mixed lighting, I usually shoot a daylight balance photo without flash to see which is the dominant color cast. I then gel for that color cast. I also use this technique on flourecent lighting when I can't tell the color.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 29, 2011 08:06 | #8 spkerer wrote in post #12115333 Not always. If you're mixing flash and ambient in your exposure, you cannot color correct in camera or in post IF your flash in un-gelled (daylight) and the ambient is tungsten. If you're using your flash to overpower the ambient light, then yes you can color correct that. If it's mixed, you can color correct for either the flash or ambient, but not both. Mixed lighting like that is when you really want to use a gel so you have a single color temp in your photograph. Well said..... Skip Douglas
LBaldwin Goldmember 4,490 posts Likes: 4 Joined Mar 2006 Location: San Jose,CA More info | Mar 29, 2011 08:22 | #9 spkerer wrote in post #12115333 Not always. If you're mixing flash and ambient in your exposure, you cannot color correct in camera or in post IF your flash in un-gelled (daylight) and the ambient is tungsten. If you're using your flash to overpower the ambient light, then yes you can color correct that. If it's mixed, you can color correct for either the flash or ambient, but not both. Mixed lighting like that is when you really want to use a gel so you have a single color temp in your photograph. You are correct, BUT if you shoot and stack you can color balance indivdual images and then stack as needed, match the color and then the editor is in Love with you... Les Baldwin
Mar 29, 2011 10:17 | #10 OMG! Did I open a can of worms? Johnny J. Chin ~ J. Chin Photography
LBaldwin Goldmember 4,490 posts Likes: 4 Joined Mar 2006 Location: San Jose,CA More info | Mar 29, 2011 10:48 | #11 No you didn't open any cans... there is just more than one way to do this. If you decide to gel, you have also do some exposure correction. If you use multiple images, you have to stack and edit. If tou use a color meter you have to have enough gels to make the corrections - and voltage in the lamps can alter that too. Color correction is a HUGE can of worms, you just peeled back a bit and peeked inside. Les Baldwin
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 29, 2011 10:51 | #12 I recently did some shots of my wife cooking in our kitchen using a combination of tungsten ambient lights and wireless flash. Background of kitchen was orange relative to a daylight wife. Solution: Hugh
Mar 29, 2011 11:09 | #13 HughR wrote in post #12116438 I recently did some shots of my wife cooking in our kitchen using a combination of tungsten ambient lights and wireless flash. Background of kitchen was orange relative to a daylight wife. Solution: 1. Place full CTO gel over flash (you can use two 1/2 gels stacked, but you use a little more light that way). 2. Change camera white balance to tungsten. Otherwise, everything comes out looking orange. 3. Shoot and then check camera display. Should look just about right, and then any fine tuning can be done in post processing. Another very effective use for CTO gels is in flash portraits. Using a 1/4 CTO on the flash and auto or daylight white balance gives the subject a subtle warmer glow. Thanks for the info. That doesn't sound too hard to do and is about what I was hoping to do. Johnny J. Chin ~ J. Chin Photography
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 29, 2011 11:23 | #14 I have full CTO, 1/2 CTO, and 1/4 CTO, but I mainly use 1/4 for portraits and full CTO to balance tungsten. Lumiquest sells a kit with these plus blues, greens, a red, and a yellow gel along with a holder to put them over the flash. Check out Lumiquest (or Honl) on the web. Hugh
| Latest registered member is semonsters 1472 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
