Thread started 29 Mar 2011 (Tuesday) 17:43
Quick question on Canon teleconverters
joonrhee
Mar 29, 2011 17:43 |  #1
Can you stack 1.4xII with another 1.4xII and only lose 2 stops of light? If yes, wouldn't this actually be better than having only 2xII and losing 2 stops? Should the IQ take major hit if two 1.4x II's are stacked? At least the FL is 2.8x not 2x...
a7RII • a7C • V12 • L21 • S24GM • S85
Full Gear List & Feedback
SmugMug (external link)
gotaudi
Mar 29, 2011 17:56 |  #2
its actually 1.96X when stacked
They are multiplicative not additive
Wilt
Mar 29, 2011 18:06 |  #3
You cannot stack two Canon 1.4x teleconvertors, as they have front elements which project forward too far to fit in the backside of another 1.4x teleconvertors. (You can stack a Kenko 1.4x behind a Canon 1.4x.)
joonrhee
Mar 29, 2011 18:10 |  #4
That is right gotaudi... and thanks for the confirmation Wilt.
Nevermind the original question.
gasrocks
Apr 01, 2011 08:40 |  #5
When they say it is a 1.4x Tc they actually meant square root of 2 and abbrev. 2 1.4x TCs is the same as a 2x TC. More glass though. Shooting wide open the 2x TC will be better, stopped down a ways it is a horse race. You can stack Kenko and Tamron TCs.
joonrhee
Apr 01, 2011 09:02 |  #6
Just out of curiosity, Canon 1.4x II + Kenko 1.4 is better than Canon 2x II? I just don't like the amount of IQ degradation when used with Canon 2x II & III...
Silverfox1
Apr 01, 2011 09:12 as a reply to  @ joonrhee's post |  #7
I realize your questions are in regards to using the Canon extenders but i did recently perform some rather extensive testing using the Kenko converters and a Vivitar 2x MC7 that gasrocks mailed me for testing also.
You can view the stacked results below and a variety of other converter tests performed on both the 70-200MKII & 100-400L lenses in my signature:
Stacked Tests here:
https://photography-on-the.net …p?p=11887106#po​st11887106
Regards, ;)
Silverfox1 POTN Feedback / TC Extender Tests / Gear List
Wilt
Apr 01, 2011 10:25 |  #8
Since Silverfox1 posted results with stacking 2x and 1.4x teleconvertors, I will offer the results of stacking two 1.4x teleconvertors, with 70-200mm f/4 IS lens...camera position moved to keep subject fixed in size for direct comparison reasons.
lens only:
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/IMG_4497.jpg
Canon 1.4x:
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/IMG_4496.jpg
Canon 1.4x+Kenko 1.4x stacked:
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/IMG_4495.jpg
joonrhee
Apr 01, 2011 11:37 |  #9
Thank you Silverfox1 and Wilt.
Hey Wilt, would you happen to have the 100% cropped comparisons?
Wilt
Apr 01, 2011 12:20 |  #10
You are already looking at only about 10% of the frame ...the (artificial) flower filled the center circle of the viewfinder -- it is what I used as the way to determine 'same size' as I moved the camera back with increased FL.
joonrhee
Apr 01, 2011 12:49 |  #11
Hey Wilt, then they look pretty darn good to me! How would you rate Canon 1.4x + Kenko 1.4x VS Canon 2x?
Wilt
Apr 01, 2011 12:54 |  #12
joonrhee wrote in post #12138634 (external link)
I cannot comment, having no experience with the 2x teleconvertors on my lens. It would be speculation.
gasrocks
Apr 01, 2011 12:59 |  #13
If you are stopping down the lens a bit - the combo you mentioned will be just fine. I used to have 2 identical Tamron SP 1.4x TCs for that reason - they fit everything and can be stacked.
Silverfox1
Apr 01, 2011 13:32 |  #14
Just remember your best IQ when either stacking two 1.4 TC`s or a single 2x on a fixed f2.8 lens will be F8.0 & F11.0
Regards, ;)
Refresh ­ Image
Apr 01, 2011 13:40 |  #15
joonrhee wrote in post #12119546 (external link)
Sure, it is even better to use 1.x extensers. Each does not loose any stops and does not intorduce any quality loss because it is 1.x. Since you do not need to do anything to get that 1.x magnification you virtually already have as many 1.x extenders as you need. They all have zero length and weight zero lbs.
So if you stack five of them you turn your 135 /2.0 into EF 650/2.0 !
3,211 views & 0 likes for this thread, 7 members have posted to it.
873 guests, 128 members online
