Thread started 29 Mar 2011 (Tuesday) 19:18
Canon 7D flashing FA11 since return from service
M4Shooter
Mar 29, 2011 19:18 |  #1
Have had my 7D for close to year now. Finally decided to send it in for inconsistent auto focus. Well the camera came back today and now on the LCD display it shows a message where the shots remaining counter is. It will show the shots remaining and then FA11 will start flashing a few seconds after the shutter is released. It continues to flash until the camera goes into sleep mode. I can't find anything in the manual on this. It came back with firmware 1.2.4 The camera seems to operate OK. Any ideas??
Canon 7D w/28-135mm kit- Canon 24-70 f/2.8L[COLOR="Black"]- Canon 300mm f/4L
yourdoinitwrong
Mar 29, 2011 19:53 |  #2
I haven't seen that on mine and I don't recall seeing any threads/posts on the forum about it either. I would be calling Canon on that one since you just got it back from them.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
apersson850
Mar 29, 2011 20:00 as a reply to  @ yourdoinitwrong's post |  #3
Should that be read as "fail"?
Anders
M4Shooter
Mar 29, 2011 21:15 as a reply to  @ apersson850's post |  #4
"Should that be read as "fail"?
That is what I orginally thought it might be. However I could not find any documentation on it and the camera seems to work fine. I will be giving Canon a call tomorrow.
Bannor
Mar 31, 2011 05:16 |  #5
Perhaps they wanted it to say f-all? :)
Bannor
Meaks
May 30, 2017 06:52 |  #6
I have the same problem, anyone found an answer please?
Bruce Meaker
Canon 7D, Sigma 10-20, Canon EF 24-105L IS, Canon EF100 macro, EX430-ll, Slik 300DX
Ramon-uk
Gallery: 41 photos
May 30, 2017 08:41 as a reply to  @ Meaks's post |  #7
If this is happening after you press the shutter then it is probably trying to write to the memory card.
Try formatting the memory card or even replace it with another one.
MikeWa
Gallery: 89 photos
Joined Apr 2012
Post edited over 1 year ago by MikeWa.
May 30, 2017 17:03 |  #8
You might see if there is a phone number on your paperwork from Canon service. Give them a call and see what they have to say.
Mike
Oh shoot I just realized this is a very old thread.
Mike...G9; 7D; 7D Mark II; EF-S 10-22mm; EF-S 18-135mm IS STM; EF 28-300mm F3.5-5.6L; EF 70-300mm IS USM; EF 70-200mm F2.8L IS-II; EF 100-400mm f4.5-5.6L IS; EXT 1.4-II & 2.0-III; The more I learn the less I know.
Meaks
Mar 12, 2018 00:20 as a reply to  @ Ramon-uk's post |  #9
No this is on the screen all the time except for a second or two when I touch the shutter release to autofocus etc.
Bruce Meaker
Ramon-uk
Gallery: 41 photos
Mar 12, 2018 06:29 |  #10
Meaks wrote in post #18583299 (external link)
It is still worth doing a low level format of the card whilst it is in the camera, if the camera thinks the card is full or damaged then it cannot calculate the number of possible shots.
chuckmiller
Joined May 2012
Mar 12, 2018 07:38 |  #11
Meaks, has it done this for a year now?
Retiring from Fire/Rescue after 37 years on 6/30/2020 and counting the days
John ­ from ­ PA
Joined May 2003
Post edited 3 months ago by John from PA. (7 edits in all)
Mar 12, 2018 08:03 |  #12
Too bad the OP hasn't been on the forum since 2015 so no chance to learn what he/she did. But I'd reflash the firmware...see https://www.usa.canon.​com …subtab=download​s-firmware (external link) for the download.
[Edit]Added information on the error message. See http://www.fredmiranda​.com/forum/topic/12118​99 (external link) and specifically the content at the last entry which I've quoted below. Unfortunately the camera may have to go back to the service shop for a few steps not previously done by the technician.
So, an update on this situation...
Canon AUS was not able to advise what caused this 'error' message, except to say that they were sure that it wasn't an error and that the camera was fine to use and should operate normally. They contacted Canon Japan for more information, which took a few days, but they got the answer. When the techs adjusted the lenses to the camera, the camera is plugged into their computer/system, and needs to switched into some special mode that allows the AF adjustments to be made. When the adjustments have been completed, the camera should be switched back out of that adjustment mode by flicking a switch or ticking a box in the computer software (not in the camera). It seems that step was not performed when the adjustments were completed. The message probably means "FAII" for Focus Adjustment II, or something like that.
I'm waiting to receive the camera back tomorrow or the day after. So nothing to be concerned about, but it seems the Canon techs had a bit of a fail moment on a simple task.
Meaks
Mar 14, 2018 14:13 as a reply to  @ chuckmiller's post |  #13
Yes it had
Bruce Meaker
Meaks
Mar 14, 2018 15:20 as a reply to  @ John from PA's post |  #14
Thank you, I will contact my service centre
Bruce Meaker
5,083 views & 1 like for this thread
Latest registered member is Elemental13
792 guests, 342 members online
