Thread started 29 Mar 2011 (Tuesday) 23:10
What happed
crazyman229
Mar 29, 2011 23:10 |  #1
took a picture looks like this and them now error 99
need some help
bdpaco
Mar 29, 2011 23:15 |  #2
looks like its time for a new shutter
My Blog
http://rickbandaphotog​raphy.blogspot.com/ (external link)
My Website
www.rickbandaphoto.com (external link)
SkedAddled
Gallery: 16 photos
Mar 30, 2011 00:53 |  #3
If I'm seeing a wineglass with some red wine in it, then bdpaco is correct about the shutter.
The shutter assembly probably needs to be serviced/replaced.
If you offer up some information about the camera model, others may be able to offer up
some good tips about getting it serviced.
Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Support this exceptional forum
Of course I'm all right! Why? What have you heard?!?
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Mar 30, 2011 01:50 |  #4
the shutter - it eeez fawlty...
looks like it can be repaired for about USD$150 see: http://cgi.ebay.com …ain_0&hash=item​4aa8474766 (external link)
worth asking Canon what they'd charge to do the same thing, you never know it might be cheaper.
TF posting: here :-)
Bleufire
Mar 30, 2011 01:52 |  #5
looks like you had too much wine is what happed. JK
SkedAddled wrote in post #12122060 (external link)
Exif info shows XSi
5D*Sigma 50/1.4*EF 17-40/4
New to Photography? ----> ENJOY! Canon DSLR! (external link)
SkedAddled
Gallery: 16 photos
Mar 30, 2011 02:00 as a reply to  @ Bleufire's post |  #6
Bleufire wrote:
Exif info shows XSi
Can't view that when I'm not on one of
my own systems, thanks.
OP: Not sure how the XSi holds up to shutter actuations, but I'd recommend posting
as accurate of a shutter count as possible, so that the truly seasoned people here
can best advise you as to how to approach the situation.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 30, 2011 06:00 |  #7
There are only 3 viable options:
1) Send it in to Canon and either they replace it under warranty or you pay their quote
2) You repair it yourself
3) You sell it for parts and buy a new camera
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Mar 30, 2011 06:05 |  #8
how many shutter actuation's does the camera have?
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
Smurff
Gallery: 43 photos
Mar 30, 2011 06:19 |  #9
i know just about nothing about shutters so a quick question if someone could help me :D
i thought a shutter would leave a flat line(filled with black), like if you dont set your flash right you get that flat line across an image. what would cause the curtain to brake in this sort of way(pictured) how are they mounted / work?
and how do aperture blades sit, i always thought they were at an angle of sorts, if one wasnt working, it would look like this(pictured)?
sorry, just thought i would ask as i can try learn and its kinda on the subject of this :D
-smurff
PaulB
Joined Apr 2003
Mar 30, 2011 06:22 |  #10
mike_311 wrote in post #12122926 (external link)
Does that matter now it has so obviously failed?
If the camera is in warranty then it's covered, if it isn't then time to get it repaired or replace the camera.
All this 'failed with only X,000 shots' is a waste of discussion time - shutters are mechanical and high precision mechanisms, they fail eventually whether at 1 click or 250,000, or more, or in between!
I know this post won't make the OP feel any better but neither will all the "Canon have screwed you" posts which will fill pages and pages - actually, no they haven't screwed you actually, just one of those things...............
Bend ­ The ­ Light
Mar 30, 2011 06:29 |  #11
Smurff wrote in post #12122950 (external link)
-smurff
Have you tried another lens?
If it's still bad, then it's the camera, I would have thought. If it's good, then the lens is at fault.
mike_311
Gallery: 18 photos
Joined Mar 2011
Mar 30, 2011 06:30 |  #12
PaulB wrote in post #12122959 (external link)
not really, but some of us are curious, if it fails with under 100K its a bit alarming.
Smurff
Gallery: 43 photos
Mar 30, 2011 06:31 |  #13
Bend The Light wrote in post #12122977 (external link)
think you quoted me by mistake, not the OP, as i dont know what your reply has to do with me :) :p
-smurff
PaulB
Joined Apr 2003
Mar 30, 2011 06:39 |  #14
i thought a shutter was a flat line, like if you dont set your flash right you get that flat line across an image. what would cause the curtain to brake in this sort of way(pictured) how are they mounted / work?
-smurff
Canon shutters are made up of overlapping extremely thin 'blades' (used to be of carbon and super duralmin, 10 blades in all) of which, in my 1series cameras, the top one has a rounded corner exactly like the shadow in the OP's image.
The shutter blades are fixed (riveted?) to a parallelogram arm and if one of the fixings fails then a blade will usually drop at an angle as in the OP's image - my 1DMkII failed (at around 40K shots) like that but didn't give any errors.
Smurff
Gallery: 43 photos
Mar 30, 2011 06:54 |  #15
PaulB wrote in post #12123009 (external link)
ahh i see, makes sense :D cheers for the insight. always like to try and learn something new :D
-smurff
4,123 views & 0 likes for this thread, 16 members have posted to it.
What happed
1655 guests, 168 members online
