Thread started 30 Mar 2011 (Wednesday) 22:26
eye problems
momoe
Joined Sep 2009
Mar 30, 2011 22:26 |  #1
I've tried to shoot eyes. I have seen some great eye shots but mine are rather unremarkable. I want to know how people get the deep, rich textures and colors. I see some portraits where the subjects eyes are just fantastic but mine are dull. I select the focal point to fall on the eyes and I lighten them in post when they need it but I have trouble altering the color to make them more appealing. what are your tips and secrets?
Wallpap3r
Mar 31, 2011 03:50 |  #2
Try sharpening them a lot (the colored part of the eye) increasing saturation, and maybe contrast
40D || 50 1.8 II || 18-55IS || 85 1.8 || 430EXII || YN560 x2 || Cheap umbrellas x2 || QBox 24 || Cheap macro crap
queenbee288
Gallery: 17 photos
Joined Dec 2004
Apr 04, 2011 04:51 |  #3
I use brightness and contrast on the eyes. Or levels adjustment. Of course it helps to have nice eyes to work with.
RKruegerPhotoNJ
Apr 13, 2011 10:54 |  #4
When working with eyes, I usually do the following in Photoshop:
1. Create a new layer that contains just the sujects eyes
2. Use the dodge tool on the iris, avoiding the pupil and perimeter of the iris as much as you can. Don't overdo it here - you just want to dodge enough to brighten the iris, not make it white...
- Brush Hardness: 10%
- Range: Midtones
- Exposure: 20%
3. Use the burn tool to darken the iris perimeter and pupil - again, don't overdo it. When you think you've darkened them enough, you probably have
- Brush Hardness: 5-10%
- Brush Range: Shadows
- Exposure: no greater than 15%
Finally, I adjust the opacity on the "Eye Pop" layer accordingly, dependent on how much of an effect I'm going for.
Check the "Jen" gallery on my SmugMug site. That's the technique I've used on the shots (specifically the closer face-only shots)
Hope that helps!
-Rick
Rick Krueger - Morristown, NJ
My Website (external link) | Model Mayhem (external link) | Facebook (external link)
momoe
Joined Sep 2009
Apr 13, 2011 11:32 |  #5
very nice. I will be trying this soon
RDKirk
Adorama says I'm "packed."
Joined May 2004
Apr 14, 2011 08:21 as a reply to  @ momoe's post |  #6
First, if you're using artificial lighting, be sure to have lighted the eyes properly. If you get the light enough toward the front (without being fully frontal and flat) so that the light enters the cornea at the right angle, it will brightly illuminate a crecent-shaped area of the iris opposite the catchlight.
In addition to that, there are some standard "cleanup" tasks I perform on eyes:
1. Clone out veins.
2. Use the lasso selector to select the white areas (all at once, not one at a time), then desaturate them about 40 percent to lessen any red or yellow cases, and brighten them very slightly (set brightness to 3 or 4). The desaturation is more important than the brightness--a healthy young eyeball is light grayish, not red, yellow, or bright white. Make sure you don't remove any of the corner and lid shadows that give the eyeball its spherical, lidded appearance. Eyeballs need spherical shading to look properly round, and eyelids have definite thickness that normally casts a rim of shadow on the balls.
3. Remove fill flash catchlights and any other catchlight clutter (secondary windows, et cetera). A clear, clean single catchlight makes the eyes look clearer and cleaner.
4. Often the eye closer to the main light will have a larger, brighter catchlight than the opposite eye. I'll copy that larger catchlight and paste it over the smaller one--very carefully, because the slightest misalignment will make the eyes look like their pointed in different directions (this is also a way to subtly correct eyes that actually are looking in different directions). Usually I copy the entire iris, paste it at a lower opacity to get the pasted iris registered precisely over the original iris, then erase away the unnecessary parts of the pasted iris.
5. Enhance the illumination of the iris. I mentioned that a properly illuminated iris will have a crecent-shaped bright area opposite the catchlight. If it's not there, I'll put it there. But you have to be careful with brown eyes--you can't just dodge a clipped brown eye lighter. You have to get some semblence of the natural texture of the iris into brown eyes. I set the clone tool to about 40% opacity and then clone from the eyebrows to create the crecent shape. That gives me some of the texture that makes it look more like an illuminated brown iris. Yes, you can probably find brushes for that, but I find that a 40% skin-tone-plus-hair brush is instantly available from the eyebrow.
6. With lighter eyes I'll lasso the irises (both at the same time) and apply curves to lighten the lighter tones and darken the darker tones, that is, increase the internal contrast. Then while the irises are still lassoed, I'll sharpen them a bit. I prefer using curves rather than burning in tones that aren't really there.
1,269 views & 0 likes for this thread, 5 members have posted to it.
eye problems
2689 guests, 139 members online
