Thread started 31 Mar 2011 (Thursday) 08:16
EX Flashgun not compatible with 30D!
Tendy
Mar 31, 2011 08:16 |  #1
OK this is odd. I spied a used 420EX for £79 in a camera shop, gets set to buy it but get told it wont work with the 30D, manual flash only! I thought ALL EX series flashguns worked on ALL EOS cameras? If not why not? Same for my Canon off camera cord II-that wont work with the 30d either! What a carry on!
5D | 30D | Canon IXUS 265HS | Oppo Smartphone
My photo blog:
http://inventedeye.blo​gspot.com/ (external link)
My Photography Page
https://www.facebook.c​om/LarryShonePhotograp​hy (external link)
BrandonSi
Nevermind.. I'm silly.
Gallery: 62 photos
Joined Sep 2004
Mar 31, 2011 08:22 |  #2
Well, it is over 10 years old, and pre-dates the 30D by at least 5 years.. There are plenty of other options for current flashes. :)
[ www (external link)· flickr (external link)]
Tendy
Mar 31, 2011 08:25 |  #3
BrandonSi wrote in post #12130422 (external link)
Hmm, yes! But the off camera cord too?
My photo blog:
My Photography Page
BrandonSi
Gallery: 62 photos
Joined Sep 2004
Mar 31, 2011 08:27 |  #4
The camera cord won't work at all, or only in manual? I imagine it will work OK in manual mode.
Kechar
Joined Mar 2011
Mar 31, 2011 08:27 |  #5
I searched around a little and found the following...
Hi, i've just upgrade from a 300D to a 30D. i also have a 420EX flash that work fine with my 300D. But when i use it with the 30D there is a lot of picture that are underexpose. It it because of the E-TTL / E-TTL II compatibility ?.
Eric Labrecque
The difference in exposure is TOTALLY a function of the difference in the camera flash metering system.
The 300D is ETTL. ETTL will heavily bias exposure to the focus point.
The 300D is ETTL-II. ETTL-II averages exposure across the entire frame, BUT will limit flash output to prevent overexposing any of the flash metering zones.
The 420EX is 100% fully ETTL-II compatible.
BUT, where as the 420EX will support all seven of the 300D AF points, the 420EX will not support the four "diagonal" focus points of the 20D/30D/5D.
The 420EX doesn't support the four diagonal points if you manually select them. However, if you have the camera set to pick a focus point automatically, the AF assist beam may (depending on focal length and subject distance) still cover them. Not something you'd want to bet on, though.
Hope this helps
flickr (external link) KCharron.net (external link) - 5D mark III (gripped) | 24-70 2.8 VC | 85 1.8 | 50 1.4 | 70-200 2.8L
[LIGHTING: 3 Einsteins, AB400, CyberCommander, 2 VLMs w/2 spare bats, 2 64" PLMs, 24x32 softbox, 22" BD, grids and diffusers, Avenger stands and boom.]
730 views & 0 likes for this thread, 3 members have posted to it.
896 guests, 126 members online
