Thread started 31 Mar 2011 (Thursday) 15:26
Are these the exact same set of Kenko tubes?
Buylongterm
Mar 31, 2011 15:26 |  #1
http://www.amazon.com …TF8&qid=1301602​860&sr=8-3 (external link)
http://www.amazon.com …TF8&qid=1301602​997&sr=8-1 (external link)
Cause I just bought the more expensive ones!!!!
Christian
@WerthLiving (Follow me on Instagram)
Canon EOS 5D MK III Gripped | 35mm f/1.4L | 70-200mm f/2.8L IS MK II |100mm f/2.8L Macro | 24mm-105mm f/4.0L |
Saint728
Mar 31, 2011 16:10 |  #2
The more expensive ones are older. The cheaper priced ones came out in 2008 and the ones you got came out in 2001. B&H photo only sells the newer ones.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
gasrocks
Mar 31, 2011 16:16 |  #3
You want Kenko DG.
Mark-B
Mar 31, 2011 16:18 |  #4
I was just looking at these two sets yesterday. I'm going to get the ones for $144. Kenko only lists one extension tube set on their website (http://www.kenkoglobal​.com/ (external link) and http://www.thkphoto.co​m/products/kenko/ (external link)), so I assume that both of the sets listed on Amazon are the same thing. They both have the exact same markings even though Amazon shows different model numbers. The less expensive listing has the same model number (AEXTUBEDGC) as B&H and Adorama.
Mark-B
msbphoto.comexternal link
Buylongterm
Mar 31, 2011 16:27 |  #5
gasrocks wrote in post #12133351 (external link)
You want Kenko DG.
But aren't they the same? I'm on the phone with Amazon and not sure what the hell to do
Christian
Buylongterm
Mar 31, 2011 16:28 |  #6
Saint728 wrote in post #12133312 (external link)
Take Care,
Cheers, Patrick
Is there a difference or an improvement?
Christian
SkipD
Joined Dec 2002
Mar 31, 2011 16:31 |  #7
I don't think there's anything different about those two sets except for the price and who's selling them. The lower priced set is sold directly by Amazon and the higher priced set is from a different vendor (Kellards) selling through Amazon.
Find out what the return policy is if you want to save a few coins.
Skip Douglas
Mark-B
Mar 31, 2011 16:34 |  #8
This is from the B&H website:
"This DG Extension Tube Set has upgraded "Gate-Array IC" circuitry to work better with digital SLRs and some of the digital SLR lenses*."
*Retains AF function when effective aperture stays at f/5.6 or brighter(f/8 or brighter on EOS 3, 1V & 1D cameras)
Mark-B
Saint728
Mar 31, 2011 16:34 |  #9
Buylongterm wrote in post #12133420 (external link)
Don't know what the difference is, but the older ones weigh less then the newer ones and they have a different serial number as well.
Take Care,
Cheers, Patrick
Buylongterm
Apr 01, 2011 08:51 |  #10
Mark-B wrote in post #12133454 (external link)
Very good to know! Thank you so much.
I have both sets being delivered today and looks like I''ll be returning the older model set. Amazon was great about the whole thing. Since I had them shipped overnight, I couldn't cancel the first order and the first order I used a 75.00 gift certificate. So, they added another 75.00 to my account, and I was able to apply it towards the second order without them even having the 1st order returned yet.
Christian
itzcryptic
Apr 01, 2011 09:50 |  #11
I was thinking about buying some extension tubes with some Amazon gift cards as well. I found a cheaper set from Cowboy Studio, but couldn't get an answer about whether or not it worked with EF-S lenses, so I never ordered.
Mark-B
Apr 22, 2011 16:36 |  #12
Mark-B wrote in post #12133368 (external link)
I ended up not making the purchase, but I did notice that the prices on Amazon have skyrocketed like all other camera products. $40 more expensive today than they were 3 weeks ago!
Mark-B
amfoto1
Apr 22, 2011 19:07 |  #13
Both of those Amazon sets you linked are the same and are marked "For C/AF". I have this set. It is the older version and will work fine with your two EF lenses. It will not be possible to use with EF-S lenses.
The newer ones are marked "DG" and are compatible with both EF and EF-S lenses.
I don't know of any other differences between them. As far as I can tell the circuitry is just simple 1 to 1 connections between the camera and lens, and nothing more. I haven't had a Kenko tube apart... I have had a Canon tube apart and it's nothing more than straight connections. There isn't much difference between the Canon tubes and the Kenko, other than the sizes and the markings.
Either set allows full control of the aperture and AF.
It is possible that the sellers on Amazon are just using an old picture. You might order a "C/AF" and get a "DG". Actually I thought most of the old C/AF tubesets would have been sold out by now. It's been a few years since Kenko came out with the DG and stopped making the earler version.
woos
Apr 22, 2011 21:40 |  #14
The more expensive ones contain special low dispersion air. :P
As far as I know they are just a straight through connection and don't contain circuitry but I could be wrong.
amanathia.zenfolio.com
SkipD
Joined Dec 2002
Apr 23, 2011 05:25 |  #15
amfoto1 wrote in post #12274779 (external link)
I have the earlier set of Kenko extension tubes. As manufactured, EF-S lenses will not fit onto them. However, it is very easy to modify them so that EF-S lenses will fit.
Each of the original Kenko extension tubes has a thin plastic baffle that has to be opened up to a larger diameter so that the plastic extension on an EF-S lens can fit through the baffle. This modification can be done easily using an X-acto knife or a variety of other common shop tools. No disassembly is needed to make the modification. One simply needs to make sure the debris from the cutting is removed from the tubes so that it cannot get into the camera in use.
Skip Douglas
2,584 views & 0 likes for this thread, 9 members have posted to it.
1468 guests, 130 members online
