Thread started 01 Apr 2011 (Friday) 14:40
Sekonic L-358 + RT32N + PocketWizards
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Apr 01, 2011 14:40 |  #1
So today I bougth the RT32N radio trigger for my flashmeter. I think I need to return it but before I do (can't do it until monday) I thougth I would ask if anybody have any opinions.
The radio is mounted in the flashmeter and I get the new flash trigger symbol. I can also set the channel for it. I set it to channel 1 and leave the flashmeter on the flash trigger symbol. The pocketwizard FlexTTL5 is also set to channel 1 and when I push the test button on my MiniTTL1 the flash does fire. However when I press the meterbutton on the flashmeter nothing happens.
The PocketWizards are all updated with the latest firmware and working properly. So do you think its the RT32N module that is defect ?
EDITING OF MY PHOTOS IS NOT ALLOWED
iwanadi
Apr 01, 2011 20:42 |  #2
You must set the receive channel on TT5 to standart receive channel not controlTL
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Apr 02, 2011 01:24 |  #3
Hmm then the flash fires once but on subsequent meetering the PW just flashes red.
PacAce
Joined Feb 2003
Apr 02, 2011 08:21 |  #4
tommykjensen wrote in post #12142539 (external link)
It works just fine for me. I have the FlexTT5 set to receive Standard channel 1 via the PW Utility program. The flash is in Manual mode. And it fires every time I press the Measure button on my Sekonic light meter.
When you say that the PW just flashes red, are you saying that it flashes red once every time you try to trigger the flash with the meter? Or do you mean that when you trigger the flash, it fires and then the red LED on the FlexTT5 flashes red continuously to indicate an error?
...Leo
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Apr 02, 2011 09:01 |  #5
The led flashes red 5 times. This time it did not even fire the flash the first time as it did yesterday.
PacAce
Joined Feb 2003
Apr 02, 2011 21:25 |  #6
tommykjensen wrote in post #12143469 (external link)
From the FlexTT5 manual:
Red blinking indicates an error condition. Power off the unit, reseat all connections, and power back on. If the error persists, verify your settings. For example if you are using a Standard channel to trigger a FlexTT5 with a Speedlite in it set to E-TTL, this is an error. The flash needs to be set to manual (See Manual Mode for more information).
As a last resort, hard reset the FlexTT5 by pressing and holding the Test button and turning on the FlexTT5. Keep holding the Test button until the LED flashes GREEN 4 times (usually after 10 or so seconds). Then use the PW Utility to set the unit to the Standard channel again.
...Leo
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Apr 03, 2011 01:59 |  #7
Thanks that got it to work. But then I loose the abillity to use higher shuttertimes than 1/250s. Oh well can't have it all.
3,530 views & 0 likes for this thread, 3 members have posted to it.
1449 guests, 130 members online
