Thanks for the replies, the "similar threads" yielded some good information and there are a couple of alternative ways of doing this that we will explore. Must say that the first way we tried, using self adhesive poly, then having to apply two sided adhesive tape to the board edges , then applying black tape over that to seal the cut lines, was a bit of a disaster. The various operations scratched the print, even leaving a protective cover over printed surface didn't help, the edge trimmer left substantial indents pressed into the photo, and the tape just didn't look right even though it was neatly applied.
The print went from looking great straight from the printer to looking like something you'd find for sale at a second hand flea market.
At least the only way is up and some of the other ideas found seem a lot better and less potentially damaging.
hal55
