Thread started 05 Apr 2011 (Tuesday) 15:45
Manfrotto 055XPROB Leg Warmer or Grip Options
effstop
Apr 05, 2011 15:45 |  #1
I have a 055XPROB that doesn't have the two rubber leg grips. I don't think I need the leg warmers as they are bulky but would like to have a little more grip when carrying from the car to wherever I'm going to shoot.
I can order the two grips from Manfrotto for $21 w/shipping (not too much) but wondering if anyone had ever used tennis/golf grip tape (less than $10) or if there were any alternatives that anyone has used in the past.
5D MKI | 1D MKII | 24-70mm 2.8 L | 80-200MM 2.8 L | 400mm 5.6 L |50mm 1.8
1xSHOT
Apr 05, 2011 15:55 |  #2
No experience with alternative grips, I'd also look into:
- Baseball Bat Grip Tape.
- Thin Skateboard Deck Tape thats flexible: Negative One
musashi
Location: Winchester, CA / San Diego, CA / North Hollywood, CA
Apr 05, 2011 15:56 |  #3
it didnt came with the grip? hmm... i just received mine last week. the two legs have the grip. is it optional? cant remember when i placed my order. even if its an opion, i dont think i paid extra for mine. where did you buy it from?
“You can easily judge the character of a man by how he treats those who can do nothing for him.”
--==Gear List & Feedback==--
effstop
Apr 05, 2011 15:58 |  #4
musashi wrote in post #12164417 (external link)
I came with it but my Lab decided to use it as a chew toy.
musashi
Apr 05, 2011 16:13 |  #5
Ah. I see i see. Well i know for a fact that tennis grips are really comfortable. So u can try those and let us know. :)
StealthFighter
Apr 05, 2011 18:46 |  #6
tennis/golf grip tape should work, but you might also consider hockey grip tape. it has a little bit of cushion and doesn't use adhesives. it just grips itself ontop of the previous layer like velcro.
IMAGE: http://www.infobarrel.com/media/image/24517.jpg
solara
Apr 05, 2011 19:00 |  #7
Tennis grip replacements (not tape to put over regular grips) have lots of cushioning.
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
effstop
Apr 08, 2011 00:01 |  #8
I'm actually leaning towards purchasing the OEM grips but not looking forward to removing the flip-locks but this shouldn't be too hard, right? I bought it second hand so it didn't come with manual or any sort of wrench but wrench/allen wrench should do the trick right?
musashi
Apr 08, 2011 00:16 |  #9
Last time i saw the leg warmers in their website i thought it has a zipper on the side to put it on and off? Not sure though. I gotta look again.
Edit: just saw it. It does look like it uses zippers. No need for allen wrench or to disassemble the legs.
SkipD
Joined Dec 2002
Apr 08, 2011 01:14 |  #10
One can also use foam pipe insulation (available in many hardware stores and most home improvement stores) to cover the upper leg sections of a tripod.
Skip Douglas
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 08, 2011 09:33 |  #11
SkipD wrote in post #12181422 (external link)
Like this.......
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo5/DSC_0065_640.jpg
effstop
Apr 08, 2011 10:19 |  #12
I guess I will save a few bucks and go to home depot...thanks all
SkipD
Joined Dec 2002
Apr 08, 2011 10:41 |  #13
effstop wrote in post #12183133 (external link)
If you get the right size, you won't have to wrap tape around the outside.
Foam pipe insulation typically has a strip of tape on each side of the slit. You pull off a piece of thin plastic from both sides of the slit and just press the exposed sticky surfaces together to make an essentially permanent bond.
Skip Douglas
StealthFighter
Apr 09, 2011 01:23 |  #14
SkipD wrote in post #12183240 (external link)
yep, like this
IMAGE: http://www.homedepot.ca/wcsstore/HomeDepotCanada/images/catalog/36563_4.jpg
jrsforums
Apr 09, 2011 10:01 as a reply to  @ StealthFighter's post |  #15
bicycle handlebar tape
http://www.earthboundl​ight.com …ips/tripod-leg-wraps.html (external link)
John
8,930 views & 0 likes for this thread, 9 members have posted to it and it is followed by 2 members.
Latest registered member is EBiffany
1611 guests, 98 members online
