If they both cost the same which one would you go for and why?
Bluesyfluesy Member 114 posts Joined Dec 2009 More info | Apr 06, 2011 05:51 | #1 If they both cost the same which one would you go for and why?
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Apr 06, 2011 08:19 | #2 PW2+ or PW flex/mini? For Sale: 1D, T1i, 800mm, 600mm
aaron.dunlap Goldmember 1,805 posts Joined Oct 2009 Location: USA More info | Apr 06, 2011 08:27 | #3 Why are you limiting yourself to only those two brands? Aaron
Johnnyk_1 Senior Member 345 posts Joined Dec 2010 Location: Nashville, TN More info | Apr 06, 2011 08:30 | #4 I usually on full manual so i went with PCB, if you want ETTL then go with Pocket Wizards.
dmward Cream of the Crop More info | Apr 06, 2011 08:40 | #5 I have Cyber Syncs and Pocketwizard ControlTL. David | Sharing my Insights, Knowledge & Experience
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Apr 06, 2011 11:26 | #6 dmward wrote in post #12168865 PW ControlTL also will support Einsteins (MC2) "Available February 2011" For Sale: 1D, T1i, 800mm, 600mm
Village_Idiot GREATEST POTN MEMBER EVER 3,695 posts Likes: 18 Joined Jan 2007 Location: Durt Burg, WV More info | Apr 06, 2011 12:14 | #7 Pocket Wizard is also compatible with other brands like Sekonic, Profoto, Dynalite, and others that have built in triggers. My village called. I was told that they missed me.
AlanU Cream of the Crop More info | Apr 06, 2011 12:22 | #8 What kind of PW's are you talking about??? 5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Aressem Goldmember More info | Apr 06, 2011 12:34 | #9 For me, it was a pretty easy decision. $60 vs $200 per unit. Full Manual vs. HSS and eTTL. bullet-proof reliability vs just as reliable. I went with the cybersyncs and I use them with my 580EX II, YN-560 and eventually Einstein's. Looking forward to being able to use the cyber commander on the slopes (I shoot ski/snowboard photos). Honestly, if money isn't a factor, I'd almost always say go with the PW flex/mini combo. There's a reason PW are the industry standard. If you're on a tight budget, then you need to figure out what features are important to you. If you absolutely must have HSS but don't wanna shell out the bucks, you can always go with the pixel knights. If that doesn't matter either and you're also not wanting to spend $130 on a pair of cybersyncs, you can try the new YongNuo RF-603's and pick up a pair for $25. If they break, who cares?! Buy another set or consider something new :P. Just my 2 cents... Ryan Mackay WEBSITE
Apr 07, 2011 06:20 | #10 clarence wrote in post #12168797 PW2+ or PW flex/mini? Do you use speedlites at all or just monoblock strobes or both? Do you use TTL or HSS? Do you use Einsteins? Each of those answers will factor into PW vs buff triggers.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Apr 07, 2011 06:52 | #11 Bluesyfluesy wrote in post #12175183 I got myself 2 einsteins and I have the option of buying a 3 multimax unit kit [Second Hand fully working] for around $400 If you can check it out before you buy it, make sure that it's got a mini USB port on the side of the unit where the On/Rx/Tx switch is. If it has it, it's the latest version of the MultiMax and the firmware can be updated via the USB port. In that case, you'd be getting a good deal on the MM unit, IMHO. ...Leo
clarence Goldmember 2,204 posts Likes: 1 Joined May 2008 Location: Northern VA More info | Apr 07, 2011 13:27 | #12 If you have 2 Einsteins, the PCB CyberCommander will be a much better solution than the PW MM. For Sale: 1D, T1i, 800mm, 600mm
Kechar Goldmember 1,699 posts Likes: 3 Joined Mar 2011 Location: Atlanta, Georgia More info | Apr 07, 2011 13:31 | #13 I have 2 Einsteins and the CyberCommander...brainless operation. flickr
| Latest registered member was a spammer, and banned as such! 2677 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
