Thread started 06 Apr 2011 (Wednesday) 19:13
YN465 Trouble
JustinRageth
Apr 06, 2011 19:13 |  #1
I bought the yn465 on ebay and dont think that it works. I put it on my camera, turn it on to "ttl" have my camera take a picture and it doesnt fire. I am in a partially dark room and it doesnt work. I press the pilot button and it still doesnt fire. Am i missing something or is it defective? This is my first flash so im not quite sure how it works.
T4i Gripped, Sigma 17-70mm, 70-200 f/4L, 50mm 1.8
Panasonic TZ5
Flicker (external link)
JustinRageth
Apr 06, 2011 20:14 |  #2
anyone?
Panasonic TZ5
dparisoe
Joined Nov 2010
Apr 06, 2011 20:38 |  #3
I'm not sure about the yongnues but my 430ex ii flashes when I press the pilot button, I would imagine it would also.
Canon 6D Gripped | 24-105 L f/4 IS | Canon 50mm f/1.4 | Sigma 70-200mm f2.8 EX DG OS HSM | 430EX II
JustinRageth
Apr 06, 2011 23:40 |  #4
i was assuming the same thing. and when i take pics, its like the camera adjusts the settings as if it were going to flash because the shutter speed is really high...i emailed the seller in hong knog so i shall see...i guess this is why you buy canon gear
Panasonic TZ5
Mike22487
Apr 07, 2011 01:28 |  #5
Try a new set of batteries there may not be enough charge in them, what setting are you shooting in? I dont believe the camera should change settings, the ttl changes the output brightness of the flash not the camera settings
watt100
Apr 07, 2011 04:55 |  #6
JustinRageth wrote in post #12174024 (external link)
before you panic, check the batteries !
my yn465 works great!
Steve_with_asperations
Apr 07, 2011 06:59 |  #7
I too have a yn465, but not this problem. ..
Is the flash definitely set to fire in your custom functions? What mode are you using on your camera and +1 on the batteries.
7D and Gripped 30D, 17-40 f4 L, 85 f1.8 Nikkor 50mm F1.4, Strobist kit growing all the time.
JakAHearts
Gallery: 6 photos
Apr 07, 2011 07:08 |  #8
Also, their flashes are really really difficult to press the test button on. If you have fat fingers and no fingernails, forget it. :D However, it should still work on your camera.
Shane
altitude604
Apr 07, 2011 07:17 |  #9
take your time and go through the instructions.
you'll probably find the answer in there... provided you can decode their somewhat lacking English.
i've got a YN-467 and it works great. :)
Erik - Three Miles Final (external link)
- Gear List -
JustinRageth
Apr 07, 2011 12:26 |  #10
Changed the batteries, I tried pressing the pilot button with a pencil tip and still doesn't fire...I have my camera in portrait mode the flash icon is Onassis I look through the viewfinder but when I take the picture it doesn't flash...hmmm not sure what else to do...it should work when I press the pilot button though
Panasonic TZ5
watt100
Apr 07, 2011 14:33 |  #11
JustinRageth wrote in post #12177071 (external link)
So, when you turn the dial on and the light is red and you press the little button next to "max" it doesn't flash?
(before you even mount the flash on the camera)
JustinRageth
Apr 07, 2011 14:36 |  #12
watt100 wrote in post #12177797 (external link)
Correct, except the night is green next to max...I try in ttl and manual...the max light is on and I press the pilot button and nothing happens
Panasonic TZ5
1,691 views & 0 likes for this thread
YN465 Trouble
Latest registered member is LaurensW
2284 guests, 307 members online
