Thread started 08 Apr 2011 (Friday) 11:36
DPP wont see my edited image's
V-Wiz
Joined Sep 2009
Apr 08, 2011 11:36 |  #1
Hi guys & gals, im back again, for some help ;). After editing my photos in CS5, DPP wont see/open the edited files. I save them as JPEG. I would appreciate any help. Thank you.
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
tonylong
...winded
Gallery: 60 photos
Apr 08, 2011 14:30 |  #2
When you say it won't "see" them, are you saying that it sees the files, but not the thumbnails, or that the files just don't show up?
Tony
ChasP505
"brain damaged old guy"
Apr 09, 2011 12:12 |  #3
This and similar problems have been discussed recently. DPP often has issues with files edited and saved in Photoshop. Are you saving with the Exif data intact? What color space?
Chas P
tkerr
Apr 09, 2011 12:57 |  #4
DPP has a problem with edited images when saved using certain kind of compression; not just jpeg.
Tim Kerr
F1, try it you'll like it.
V-Wiz
Joined Sep 2009
Apr 09, 2011 13:03 |  #5
Thanks fellas, correct they just won't show up. Yes when saved the exif info is also created. Id have to check on the color space to give you a correct answer. Thanks again guys
tonylong
...winded
Gallery: 60 photos
Apr 09, 2011 14:24 |  #6
V-Wiz wrote in post #12189742 (external link)
Hmm, have you verified that they are actually in the correct folder? As far as I've seen DPP should at least see the file, just show a "blank" thumbnail if it can't process the file.
But, as has been said, it can have problems with the output from other software, so if it shows the blank thumbnails, that would be why.
If you are sure the files are in the proper folder but there are not even the blank thumbnails, I don't know what the problem could be.
Tony
774 views & 0 likes for this thread, 4 members have posted to it.
2814 guests, 158 members online
