Thread started 08 Apr 2011 (Friday) 11:40
My first Rodeo shoot - Tips, comments?
PhotoJourno
High Plains Chimper
Apr 08, 2011 11:40 |  #1
First time I get to go.
Looking for comments and tips from those who have gone before, and could spare me some blunders.
Best place to be, best events, etc.
My longest lens will be 250mm on a crop camera.
Thanks in advance for your comments !!
--Mario
"Sensa luce non si vede nessuna cosa"--Lorenzo Ghiberti
DC ­ Fan
Apr 08, 2011 12:07 |  #2
No different than any other action sport. You'll be looking to catch action, drama and intensity.
Focal Length: 140.0mm
Aperture: f/5.0
Exposure Time: 0.0040 s (1/250)
ISO equiv: 1600
Exposure Bias: none
Metering Mode: Matrix
Exposure: Manual
Exposure Mode: Manual
White Balance: Manual
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Focal Length: 135.0mm
Aperture: f/5.0
ISO equiv: 1600
Exposure Bias: none
Exposure: Manual
Orientation: Normal
Color Space: sRGB
You'll need to develop a sense of how the action develops and to have that action coming toward you when it's time to push the shutter button. Anticipating action is the most important part of getting dynamic images.
PhotoJourno
High Plains Chimper
Apr 08, 2011 12:40 |  #3
Thanks !! Specially for including the EXIF on those images, helps me see the 1/250 speed combined with the other parameters. I will definitely post a few after the weekend !
--Mario
clarence
Apr 08, 2011 12:41 |  #4
PhotoJourno wrote in post #12183533 (external link)
Indoors or outdoors?
Daytime or night?
I've only been to one rodeo, but I'm keeping my eye out for another one.
It was at night (6pm-9pm) and I only had one lens... a 200mm:
1
IMAGE: http://loco-photo.com/images/2010-05-15_1241.jpg
2
IMAGE: http://loco-photo.com/images/2010-05-15_1284.jpg
3
IMAGE: http://loco-photo.com/images/2010-05-15_1374.jpg
4
IMAGE: http://loco-photo.com/images/2010-05-15_1403.jpg
5
IMAGE: http://loco-photo.com/images/2010-05-15_1450.jpg
6
IMAGE: http://loco-photo.com/images/2010-05-15_2038.jpg
7
IMAGE: http://loco-photo.com/images/2010-05-15_2187.jpg
8
IMAGE: http://loco-photo.com/images/2010-05-15_2377.jpg
Get close. Get low. Shoot tight. Keep shutter speeds fast (~1/1000").
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
lazer-jock
Don't mess
Apr 09, 2011 09:02 |  #5
Light/lens
Is your longer lens is the 55-250 f/4-5.6? If you're shooting indoors with this lens, you're probably going to need some extra light (flash if the venue allows it) in order to get the fast shutter speeds mentioned earlier. If you're outside, chances are that you won't have any problems.
Focusing
Also, use AIServo focusing. The only time I would use the OneShot setting is for goat tying or something where the action is all in one spot. I would also switch over to center point AF. If you let the camera try to pick which points will be in focus it just gives it something else to get wrong (you'll have a lot of sharp pictures of the rails on the other side of the arena).
Position
I prefer to get about 1/3 of the way down the arena from the chutes on the opposite side of the arena from them. Bulls and broncs will tend to come right towards you. The way my school's arena is setup will also have the team ropers come along that side. You'll also get a chance at good face shots during the barrel racing on the close turn.
Exposure
Shoot RAW if you feel comfortable with it (and have enough card space). It will give you more flexibility in case the camera gets the exposure wrong. I would leave the ISO set to Auto unless you really need to go to a higher setting to maintain your shutter speed. You can fix a noisy picture in DPP (provided with your camera - especially if you're in RAW), but a blurry picture is unrecoverable. Take some test shots as well. What I have found shooting my Rebel XSi at these events is that the dark dirt will confuse my camera into thinking that the picture needs more light. There are options with choosing spot metering and so on that can help a bit with this.
PhotoJourno wrote in post #12183871 (external link)
The 1/250th speed is due to the use of flash strobes during the event (their fast duration stops the motion more than the shutter speed). You'll need a lot faster shutter speed if you want to stop the action.
I'm off lining my cage with newspaper.
My Gear List
MTDuke
Apr 11, 2011 15:27 as a reply to  @ lazer-jock's post |  #6
Fellow novice but I did get to shoot a rodeo Saturday night. Using a 7d indoors I found the 70-200 II to work perfectly except a few shots I needed less FL and more width (e.g., team roping as they got closer to where I was standing).
I went through college on a rodeo scholarship so I knew about where I wanted to be and angles although access in this arena was a bit tough. I ended with quite a few keepers but only have this one available to post at present. This was actually the most fun I have had yet with my camera.
IMAGE: http://anglersgrotto.smugmug.com/Hill/One-Montana-Day/2011IMG2566/1246525163_Frt3N-L.jpg
IMAGE LINK: http://anglersgrotto.s​mugmug.com …TUv#1246525163_​Frt3N-A-LB  (external link)
Glockfan
May 23, 2011 12:05 |  #7
I like the b&w rodeo pic. That horse almost looks like it is laughing as it bucks the rider.
Canon 7D | Canon 24-105 f4L IS| Canon 70-200 f4L IS
J.Napier
May 23, 2011 22:35 |  #8
Stay away from the pointy ends of them horns.
Jeff
www.jni-ss.com / (external link)Blog (external link)
Sportshooterpage (external link) / Maxpreps (external link)
Facebook  (external link)/
Fligi7
May 24, 2011 10:26 |  #9
You'll need faster shutter speeds than that to freeze the bull-bucking action.
matonanjin
May 25, 2011 12:28 |  #10
Fligi7 wrote in post #12469533 (external link)
+1. You never did answer clarence's question about indoors or out. It is a huge difference in approach.
Outside, up the ISO to get a shutter speed of at least 1/1000 and fire away. Contrary to what some do I also stop down a little to get some wiggle room on focus. Generally you are far enough away that even stopped down to 5.6-8 you are still going to get blurry background. I always use hand held meter, shoot in manual and almost always shift to the right about 2/3 stop to decrease shadows under the cowboys' hats. Generally use center point and AI servo.
Indoors, is a whole nother issue. You have to up the ISO to get a marginally acceptable shutter speed which I consider 1/500th. If, as someone asked, your lens is the 55-250 it isn't going to be fast enough. You're going to have to have a lens at least 2.8 and I find I always have to go to a 2.0 prime. I use a 100 f/2.0. White balance is a PIA. Shoot in Raw and adjust in post. Some will say to use a custom WB but the gas lamps in most indoor facilities have "shifting" WB every 60 seconds so you still need to adjust in post anyway.
My Web Site (external link)
My Equine Photography Blog (external link)
My Stuff and Feedback
5,664 views & 0 likes for this thread, 9 members have posted to it.
1449 guests, 131 members online
