Something got into one of my external hard drives and renamed some files. These are raw files and some PSD and jpgs. They files names look like symbols. I can't rename them. Any ideas?
rw2 Goldmember 4,201 posts Likes: 3 Joined Jun 2006 Location: North Dakota More info | Apr 08, 2011 15:26 | #1 Something got into one of my external hard drives and renamed some files. These are raw files and some PSD and jpgs. They files names look like symbols. I can't rename them. Any ideas? If you're afraid of failure ... you'll never succeed!
solara Senior Member 620 posts Joined Feb 2010 More info | Apr 08, 2011 17:31 | #2 I doubt it's a virus - probably corrupted directory entries. Try running antivirus, malware scans. 5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
Apr 08, 2011 17:41 | #3 solara wrote in post #12185261 I doubt it's a virus - probably corrupted directory entries. Try running antivirus, malware scans. Then copy all the files to another drive, then try running chkdsk (if you have Windows - if a Mac, can't help you). I tried McAfee and Malware bytes with no problems found. I was told that the person using this had a windows system warning come up and clicked on that. He was visiting some web site for looking up people. If you're afraid of failure ... you'll never succeed!
Apr 08, 2011 20:09 | #4 I ran the chkdsk and that did it . Thank you for your help. If you're afraid of failure ... you'll never succeed!
Apr 09, 2011 07:52 | #5 Quite possibly it's a sign that your hard drive's days are numbered. Probably be a good idea to think aout replacing it. Definitely a good idea to make sure your backup routine is effective. Frank Hollis - Retired mass spectroscopist
Apr 09, 2011 10:10 | #6 hollis_f wrote in post #12188643 Quite possibly it's a sign that your hard drive's days are numbered. Probably be a good idea to think aout replacing it. Definitely a good idea to make sure your backup routine is effective. Thanks since it just reverted again after I was able to back up the few files I had not gotten to yet, that's the plan. If you're afraid of failure ... you'll never succeed!
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Apr 09, 2011 12:25 | #7 rw2 wrote in post #12185331 ...I was told that the person using this had a windows system warning come up and clicked on that. He was visiting some web site for looking up people... I'm confused... Some "person" gained access to your external drive? Who told you this? Chas P
PeterWem Senior Member 270 posts Likes: 9 Joined May 2007 Location: Skåne, Sweden More info | About malware and Windows. Don´t run your windows as an admin. That´s how people installing malware. I would even say that running windows not as admin are more safe than to use an antivirus.
sbattey Goldmember 1,250 posts Joined Mar 2011 More info | Apr 10, 2011 15:54 | #9 Permanent banrw2 wrote in post #12189155 Thanks since it just reverted again after I was able to back up the few files I had not gotten to yet, that's the plan. at least hard drives are cheap Canon 7D | Canon 50mm f/1.4 | 430EX II
aphphoto Senior Member 455 posts Likes: 52 Joined Nov 2010 More info | Apr 17, 2011 14:31 | #10 With an external drive this can also be a sign that you are not removing the drive properly. Most people just unplug the drive when they are finished with it and this is not "best practice". Instead go to the USB devices icon in the system tray, right click, go to safely remove hardware, select the appropriate drive and allow windows to "eject" the drive. Now unplug. who gives a rat crap how much gear you can list?
| Latest registered member is Monkeytoes 1350 guests, 190 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
