Thread started 11 Apr 2011 (Monday) 06:06
LR3 - drop shadows?
John_N
Joined Sep 2009
Apr 11, 2011 06:06 |  #1
Hi all,
I'm looking to add a simple drop shadow around my image for export to flickr, something I thought would be simple, but oddly I cannot find it.
I know LR/Mogrify 2 (external link) can do all sorts as I use it, however it seems to be missing from that too.
Any suggestions?
Thanks,
John
flickr (external link) (magsnorton)
: Google+ (external link) : My Site (external link) : 5oopx (external link)
John_N
Joined Sep 2009
Apr 11, 2011 06:28 |  #2
In case you're wondering about the general effect its something like this (but without the rounded corners)
IMAGE: https://lh6.googleusercontent.com/_yKtvaNpvvwI/RnfmqxRfg2I/AAAAAAAAABQ/B8wqx1GhWRY/DSCN1573_001.JPG
Going further down the mogrify route I contacted the author (who is a great guy by the way) to see if it possible to utilise the -shadow command from imagemagick in the end command line parameters and will keep you all posted.
I did just try that but got a blank white image.
John_N
Joined Sep 2009
Apr 11, 2011 09:46 |  #3
Okay, I got it cracked.
I got a reply from the author (very quickly initially) and he said he didn't think it could be done, he is right but that is because to make a drop shadow you need to use the +clone option which is only available in the convert command of ImageMagick, but sadly not in mogrify (I'm not sure why he used mogrify over convert as I think its just a cut down version but otherwise appears the same)
Anyway the way I got it working is via another plugin which has broader scope if you;re willing to do a little work yourself, and the great thing is as a plugin it works with LR/Mogrify as well.
The plugin is "Jeffrey’s “Run Any Command” Lightroom Export Plugin" (external link) and is very simple, just slap a command in and it will run it.
Here is the command I used:
"C:\Program Files\ImageMagick-6.6.9-Q16\convert.exe" "{FILE}" -bordercolor Black -border 1×1 -bordercolor White -border 1%×1% ( +clone -background black -shadow 60x5+10+10 ) +swap -background white -layers merge +repage "{FILE}"
Simply broken down it runs convert from ImageMagick passes the {FILE} (that is the full file and its location - lightroom makes a temp file for upload), adds a thin black border, adds a percent based white one, clones the image and makes it a drop shadow, swaps the images so that the original is on top and merges then back together.
Well that the way I think it works!
One thats done I applied a 4% white border and text using the LR/Mogrify plugin.
All in all you get something like this:
tzalman
Fatal attraction.
Apr 11, 2011 16:42 |  #4
You can do it without the plugin by using the Slideshow module's "Export Jpg Slideshow" option.
Elie / אלי
John_N
Joined Sep 2009
Apr 12, 2011 08:05 |  #5
Thats good to know, but I'm wanting to upload directly to flckr without the extra step, which I believe you would have to do if you export to jpg first.
Thanks for the tip though.
1,723 views & 0 likes for this thread, 2 members have posted to it.
LR3 - drop shadows?
1460 guests, 129 members online
