Thread started 12 Apr 2011 (Tuesday) 09:43
Inconsistent High Speed Sync
Alendi
Joined Apr 2011
Apr 12, 2011 09:43 |  #1
Hello fellow Canon users. A moment of your time, please.
Here's my situation. Sometimes when I'm shooting quick editorial pieces, I'll pack up a 580ex-- along with a few Canon 430exIIs. Normally I use them in manual wireless, on a 5D MkII, and rarely need to exceed the max sync speed of 1/200th of a second. Today I was outside doing a portrait, and I wanted to shoot at f/2, for a nice creamy background. When I set the wireless system up in manual, my chimping yielded frames that were blased over exposed, with a a dark shutter curtain line along the bottom. Puzzled, I switched to ETTL-II, and the frames were properly exposed. Is Canon proprietary off camera wireless flash HSS limited to ETTL mode? I was sure you could set the flash power output manually.
Cheers!
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 12, 2011 10:50 |  #2
My 7D, 580EX II(master) and 430EX II(slave) can shoot HSS in manual.
Are you using the Canon proprietary wireless system? (580EX to trigger the 430EX II's)
clarence
Apr 12, 2011 10:57 |  #3
Did you press the 2 buttons to manually set the H mode?
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Apr 12, 2011 10:59 |  #4
How were you metering the HSS in manual. If you were using a handheld meter that reads the first flash you might get a false reading.
SkipD
Joined Dec 2002
Apr 12, 2011 11:24 |  #5
gonzogolf wrote in post #12206824 (external link)
I would not think that it is possible to use a handheld meter to measure the light from a Speedlite in HSS mode because the subject sees a whole string of pulses (which are additive to the exposure) while the meter will see one pulse and quit.
Except when the Speedlite is used in fully manual (and a conventional flash output but not HSS) mode, a handheld meter seems to me to be totally useless with Speedlites.
Skip Douglas
gonzogolf
Gallery: 561 photos
Apr 12, 2011 11:29 |  #6
SkipD wrote in post #12207012 (external link)
This is what I was thinking.
Alendi
Joined Apr 2011
Apr 12, 2011 16:08 as a reply to  @ gonzogolf's post |  #7
I am using all Canon proprietary wireless flash.
Not sure what this talk of external metering has to do with sync.
I have only selected HSS within the 5DMkII while 580exII is coupled with it, and not pressed the flash function button twice on 480ex units. Do you have to manually configure each slave at its own controls or does the HSS option from within camera automatically make all slaves fire in HSS?
Also, is there a difference between 430ex and 430exII units with regards to wireless HSS functionality?
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 12, 2011 16:23 |  #8
I think your problems might be in setting the 430EX II's to manual mode. I always leave my slaves in ETTL. They will automatically fire in manual mode if the master is in manual.
EDIT: Disregard, I tried to recreate the problem and found it is impossible to set the 430EX II to manual while in slave mode.
Sorry, I don't know what your problem could be.
dmward
Gallery: 29 photos
Apr 12, 2011 22:50 |  #9
The Speedlites were not properly set in manual mode and causing over exposure. The black area in the frame was because you had shutter over sync speed without having HSS activated.
It pays to practice with your equipment before getting on the job. The fact that all worked well in TTL strongly suggests what the NTSB calls "pilot error".
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 13, 2011 07:01 |  #10
Does the problem happen every time you use wireless manual and HSS?
I don't think it should make any difference, but what do you have your Firing Group set to? Have you tried other settings?
1) A+B+C
2) A:B
3) A:B C
Are the batteries all fully charged?
Alendi
Joined Apr 2011
Apr 13, 2011 13:41 as a reply to  @ dmward's post |  #11
@dmward: I had practiced with the gear, and was certain a HSS wireless environment could be achieved in manual mode by simply indicating to the master unit that I desired high speed and manual. As msowsun has indicated, you cannot change flash types on 430exII units when in slave mode.
So, can anyone say with certainty that HSS is not possible in manual mode? It makes no sense that you'd have to set each to manual at the unit, but not to HSS (or ETTL even, for that matter.). Someone test it out for me, lemme know what u get back.
Methodical
Gallery: 239 photos
Apr 13, 2011 13:54 |  #12
I use Canon 580ex II HSS in manual mode during wildlife shotos, but the flash is attached to the camera. When it sees a SS higher than the max, it goes into HSS, but when it's lower than max, it may overexpose the image.
Gear
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 13, 2011 18:16 |  #13
Yes, as i said earlier, you CAN do HSS in wireless manual. No need to touch anything on the 430EX II other than turn it on and set it to slave mode. You set everything on the 580EX II master, and the 430EX II just does what it is commanded.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Apr 13, 2011 18:56 |  #14
msowsun wrote in post #12216647 (external link)
Why bother with all the arcane bits and bobs on the 580EXII? Just use the camera's External Flash Control menu - so clear, simple and quick.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 13, 2011 19:05 |  #15
CliveyBoy wrote in post #12216874 (external link)
Actually, I do set everything on the camera's External Flash Control menu. I guess I should have said "You set everything on the 580EX II master via the camera's External Flash Control menu , and the 430EX II just does what it is commanded". :oops:
3,866 views & 0 likes for this thread, 8 members have posted to it.
2758 guests, 145 members online
