I'm guessing yes but does that mean you have to turn down their power? Are they harder to use than a comparable speedlight setup?
cameraperson Senior Member 818 posts Joined May 2010 Location: Atlanta, GA. More info | Apr 12, 2011 21:54 | #1 I'm guessing yes but does that mean you have to turn down their power? Are they harder to use than a comparable speedlight setup? Xsi, 18-55
Apr 12, 2011 21:59 | #2 You can try to find a Guide Number for a studio light that your interested in. In most cases yes, studio lights are more powerful, just avoid the $30-$50 studio lights.
dave_p Senior Member 675 posts Joined Feb 2008 Location: Kansas City More info | Apr 12, 2011 22:01 | #3 The most powerful speedlight in Canon's line (the 580 EX II) is around 60 watt-seconds. The weakest Alien Bee strobe (a very popular line), the AB400, is 160 watt-seconds. So it's about one and a quarter stops more powerful than the 580. There are some strobes that are as much as 3200 watt-seconds.
dave_p Senior Member 675 posts Joined Feb 2008 Location: Kansas City More info | Apr 12, 2011 22:04 | #4 Tom does make a good point about ETTL. If you are used to ETTL and not accustomed to setting your flash power and your camera manually then you'll have a learning curve.
Apr 12, 2011 22:05 | #5 yes, this helps. I was looking at the alien bee stuff and saw the vagabond mini for portability. I thought maybe I should spend a little more and get the monolights instead of the regular speedlight/flash so I could have something a little better or at least it looks like it is a little better. I don't know. Xsi, 18-55
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Apr 12, 2011 22:05 | #6 I would say in general strobes are easier to use than speedlites, but harder to move around. So pick your poison. Taylor
Apr 12, 2011 22:12 | #7 tkbslc wrote in post #12210903 I would say in general strobes are easier to use than speedlites, but harder to move around. So pick your poison. ETTL can sometimes be harder to use because it gets too smart for its own good. Once you know the settings you would use for a particular shot, going manual gets you there every time, where as ETTL, like camera metering, may not always agree with what you had in your head. When you "go manual" does the camera still autofocus or do you just mean the aperture and shutter speeds are manual? Why can't you use program mode? Xsi, 18-55
gonzogolf dumb remark memorialized More info | Apr 12, 2011 22:18 | #8 cameraperson wrote in post #12210944 When you "go manual" does the camera still autofocus or do you just mean the aperture and shutter speeds are manual? Why can't you use program mode? Manual just means you select the power of the flashes. You would also be using the camera in M mode to select the aperture to match the flash power you select, and an appropriate shutter speed. Auto focus would be unaffected. You cant use program mode because there is no communication between monolights and your camera other than the fire signal.
dmward Cream of the Crop More info | Apr 12, 2011 22:43 | #9 Monolights and Speedlites are different lighting technologies for different jobs. David | Sharing my Insights, Knowledge & Experience
alessandro2009 Goldmember 2,095 posts Likes: 6 Joined Jun 2009 Location: Italy More info | Apr 13, 2011 05:08 | #10 tkbslc wrote in post #12210903 I would say in general strobes are easier to use than speedlites, but harder to move around. +1
| Latest registered member was a spammer, and banned as such! 2759 guests, 145 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
