In the menu section it just goes up to 1600. Is there another way to set it? I'd like AutoISO to go to 3200 in appropriate situations.
Adam
Apr 13, 2011 10:57 | #1 In the menu section it just goes up to 1600. Is there another way to set it? I'd like AutoISO to go to 3200 in appropriate situations. Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
Geodude Member 55 posts Joined Oct 2010 Location: United Kingdom More info | Apr 13, 2011 15:14 | #2 adammazza wrote in post #12213818 In the menu section it just goes up to 1600. Is there another way to set it? I'd like AutoISO to go to 3200 in appropriate situations. Thanks Adam Try Low Light candle setting on the top dial........although the camera still decides whether to go to 3200 or not based on available light
Apr 13, 2011 15:37 | #3 Geodude wrote in post #12215582 Try Low Light candle setting on the top dial........although the camera still decides whether to go to 3200 or not based on available light Well, What I'm trying to do is to allow it to go to 3200 via AutoISO. Problem is under the Max AutoISO setting 3200 isn't an option. Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
reefvilla Goldmember More info | Mine will go to 3200 in P mode -----------Canon EOS R -----------
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | Apr 15, 2011 14:16 | #5 Canon doesn't really want you to be disappointed with the image quality and at ISO 3200 there is a pretty good chance you will be. They limit the ISO range on purpose. Taylor
Apr 15, 2011 14:20 | #6 tkbslc wrote in post #12228929 Canon doesn't really want you to be disappointed with the image quality and at ISO 3200 there is a pretty good chance you will be. They limit the ISO range on purpose. I'm not sure I follow. It's on there, and apparently can be gotten to in 'P'. Why limit in Av, but not P? I haven't checked Tv yet. Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
| Latest registered member is Monkeytoes 1335 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
