Thread started 14 Apr 2011 (Thursday) 03:10
Help with indoor portrait settings for 550d
plam_1980
Joined Apr 2011
Apr 14, 2011 03:10 |  #1
Hi there,
I want to experiment with some indoor portraits with my 550d and the regular kit lens. i have no professional lighting nor light meter. The light can be natural and very strong (but I don't like the background) or incandescent (very soft plus two additionally possible night lamps). Can you please advise on the manual settings that can give best results given the circumstances - f 5.6, high ISO? I am a novice as you can guess
P.S. If a change in lens will give better results, please advise for some affordable ones that I can switch to
Canon 550 D, Canon EF-S 18-55mm f/3.5-5.6 IS
egordon99
Apr 14, 2011 06:35 |  #2
Buy a 430EXII flash. Learn to bounce the light.
RKruegerPhotoNJ
Apr 14, 2011 11:39 |  #3
plam_1980 wrote in post #12219109 (external link)
Define "affordable" - then we can!
A 430EX II, Flash Zebra Off-Camera ETTL cord, cheap lightstand and a reflector will help immensely! Plenty of folks using one speedlight and a reflector for some great portraits!
Rick Krueger - Morristown, NJ
My Website (external link) | Model Mayhem (external link) | Facebook (external link)
xishnik
Apr 14, 2011 22:15 |  #4
+1 on above
You don't need to use a flash. a lamp of any kind will be good. the stronger the source of light the better though. if you don't like the background, just make sure little to no light from your source falls on it and subject is as far away form it as possible. expose for subject and that would be your settings.
plam_1980
Joined Apr 2011
Apr 14, 2011 23:40 |  #5
xishnik wrote in post #12224968 (external link)
+1 on above
How to expose for subject in manual... I am really new to DSLR
TheBurningCrown
Apr 14, 2011 23:52 |  #6
plam_1980 wrote in post #12225418 (external link)
A few things.
1.) You have a light meter, it's built into your camera. You don't need an external one if you don't have a flash.
2.) There are three things you can buy to help you out tremendously.
-2a.) The book "Understanding Exposure" by Bryan Peterson. It gets recommended a lot here, and will help you learn what your camera settings do.
-2b.) A Canon 50mm f/1.8 mkII camera lens. It's referred to as the "nifty fifty" quite often on this forum. It's built like junk and has terrible autofocus, but the optical quality is great. If you have the money I would spring for the Canon 50mm f/1.4 (at ~$500 including hood since the prices have increased), but to be honest it's not much better. This will probably run you a little over $100.
-2c.) A Canon 430EXII flash. You can use this to create your own light. Just using it on your camera and bouncing it off of walls will get you started. This will probably run you about $250.
3.) For the settings with your current camera - I would use a minimum shutter of 1/80th at f/5.6 with the ISO set at whatever it needs to be to get a correct exposure. If the ISO is as high as it will go you will need to lengthen the shutter speed, but that may induce ill effects. A lens with a faster aperture (2b) or a flash (2c) would greatly help the situation, but understanding what you're doing (2a) is the most important.
If you have any more questions, just ask.
-Dave
Gear List & Feedback
plam_1980
Joined Apr 2011
Apr 15, 2011 01:08 as a reply to  @ TheBurningCrown's post |  #7
Thanks everyone and especially TheBurningCrown for the advices! I have Michael Freeman's "Perfect Exposure", but it is too advanced for me, I guess.
Promise I will inform you for the results :)
Sleepy ­ Owl
Joined Mar 2011
Apr 15, 2011 09:02 |  #8
This is where I got started. He has lots of little videos, and teaches in a straight forward way.
http://www.michaelthem​entor.com/lessons.cfm?​lessonCatID=1 (external link)
I actually bought the video for the 550d that he sells. That helped me too.
~Laura~
Canon T2i ~ 18-55mm kit, 55-250mm f/4-5.6 IS
11,774 views & 0 likes for this thread, 6 members have posted to it.
2689 guests, 139 members online
