Just both a Vagabond II and have some queries regarding its use
1. The manual says I need to recharge after every use.
Do I need to recharge even if it had been fully charged and I've only shot around 10 test shots .
2. It Also says it is very important to connect the VII's Battery to the charger after Each use.
Isn't the Battery connected to the charger/inverter by default?
3. It says that VII system includes a Ground Fault Circuit interrupter that detects ground faults and shuts down the inverter preventing a shock Hazard .
If that is the case why does the unit have a Grounding input on the control panel.
Is there anything else I need to know to increase the efficiency or longevity of the Vagabond II
Any advice or suggestions will be very much appreciated.
Thanks in advance.
