I need to do this for my new photography job. I don't have a 580 for a master, or an RF-602 wireless transmitter or anything, just the 430 EX-II and 5D. Will this work? If so, how? I can't find any topics on the web that answer this. Thanks!
Chziime Hatchling 3 posts Joined Apr 2011 More info | Apr 16, 2011 12:22 | #1 I need to do this for my new photography job. I don't have a 580 for a master, or an RF-602 wireless transmitter or anything, just the 430 EX-II and 5D. Will this work? If so, how? I can't find any topics on the web that answer this. Thanks!
DazJW Senior Member 319 posts Joined Jan 2010 Location: Teesside More info | Apr 16, 2011 12:25 | #2 No, you need a 7D, 60D, 580/550EX or an ST-E2 to use as a master for Canon's wireless system.
gonzogolf dumb remark memorialized More info | Apr 16, 2011 12:25 | #3 no, not without an additional trigger device, or an off camera cord. Only the 7D and 6OD have built in wireless triggers.
Apr 16, 2011 12:30 | #4 So, what could I get that is cheapest and would work? This?
gonzogolf dumb remark memorialized More info | Apr 16, 2011 12:32 | #5 The cheapest that wlll give you full ETTL control would be a long off camera cable from www.flashzebra.com
Apr 16, 2011 13:02 | #6 Yes, I would be using manual flash since I am doing portrait photography. What are the basics I should know to slave the 430 using RF602s? For example, how would exposure figure into the added fill, and what settings do I use on the 430 to slave it manually? Thanks for any help, I have my first shoot on Wednesday and would have to order to 602s today... just busy until then.
gonzogolf dumb remark memorialized More info | Apr 16, 2011 13:45 | #7 You set the 430exII to manual mode (not in slave mode) and attach it to the RF602 receiver. Set your shutter speed below max sync on your camera, 200 or less. In M mode your flash is capable of full, 1/2, 1/4, 1/8, 1/16 etc power. You might want to start out at less than full power, that way you have the ability to adjust upward or downward as needed. Take a shot at your preferred aperture and take a look at the histogram. If you need more or less power you can either adjust the light or adjust the aperture (or ISO). Adjusting the flash power will not affect the ambient light, but changing the aperture or ISO will. Keep in mind that you are actually calculating two different exposure values in this process. One for the ambient, and one for the flash. Changing the shutter speed is the easiest tool for adjusting the ambient (area not affected by flash). Shutter speed doesnt really affect flash power as all the flash is delivered in a short burst anyway.
| Latest registered member was a spammer, and banned as such! 2871 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
