JakAHearts wrote in post #12234807
I just really like the edits I had done. Is there some way to save the history and then apply it to a new file?
There are a couple approaches.
The first uses a file to store the edits. With your "model" with the edits done selected, you can choose Edit/Save recipe in file...
It will open a browser. Just make sure you note where you save the recipe (as well as the name). Then, when you want to apply the recipe, just select the images you want to apply it to and choose Edit/Read and past recipe from file...
Again, make sure you go to the proper recipe -- not, as I just did, to one that had been previously saved by me
You can do all this in the Main window if you wish.
The other approach is that you can select and open the images you want to apply the edits to as well as the "model" image you have edited previously in the Edit window. Then, the click on the model image and choose Edit/Copy recipe to clipboard. Then, since all the "subject" images are already "selected", you can choose Edit/Paste recipe to all images. This is you will note a "one time" batch process, so if you want to have a long-term recipe to use repeatedly, saving a file with a distinct name is the best way to go.
