Thread started 16 Apr 2011 (Saturday) 22:07
wireless ettl for bracket use
pictureperf
Gallery: 44 photos
Apr 16, 2011 22:07 |  #1
is there a reasonably priced (somewhat) wireless trigger with ettl for use with a 580ex2 for use on a bracket? I want to get rid of the ocf cord as they are a pain and the Yongnuo's fall apart after awhile. BUT i dont need to spend $600 either unless i have to.
thanks!
Beauty is in the eye of the checkbook holder...
windpig
Chopped liver
Apr 16, 2011 22:09 |  #2
I use the ST-E2
Go ahead, spin the wheel.
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Apr 16, 2011 22:11 |  #3
define reasonably priced... ST-e2 would be perhaps your cheapest option at around $150-200 used. The PW controlTL system, radiopoppers, or even the pixel knight system is more pricey. Stick with the short cords
liupublic
Apr 17, 2011 09:20 |  #4
Pixel Knight (RF wireless ETTL trigger) for one flash (one receiver and one transmitter package) is about $160. Yongnuo ST-E2 clone is about $110. Search on ebay.
Yongnuo ST-E2 has better range than Canon ST-E2 and the AF assist projects further but it's line of sight only. It also rotates so you can aim it toward the flash on a bracket. It might work better for your application.
There are newer ETTL RF trigger coming in the next few months from Pixel and Phottix. No price yet. My guess is that they will be more expensive than Pixel Knight but with better functionality.
Still learning
Nikon D750, Sigma 24-105OS, 105mm 2.8g micro VR, Tamron 70-300VC
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 17, 2011 11:59 |  #5
pictureperf wrote in post #12236910 (external link)
thanks!
What camera are you using now? Have you considered upgrading to a 60D or 7D for the wireless flash capability?
enrigonz
Apr 17, 2011 12:05 |  #6
msowsun wrote in post #12239464 (external link)
Wow! You see this exactly the response I try to avoid when responding to someone asking any kind of question..... "go out and buy a new camera"
In this case I don't think buying a new camera with the wireless flash capability will work because they require line of sight. 2 flash heads on a bracket as I understand the OP wanting to do, will need a radio frequency or wire to trigger any flashes on top of the camera if the bracket is anything like mine.
Canon Stuff :) |Flickr (external link) | Facebook (external link)
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 17, 2011 12:27 |  #7
enrigonz wrote in post #12239484 (external link)
I think if you are going to spend $200-$300 on some form of ETTL wireless capability, spending the same money on a camera upgrade that could accomplish the same thing for you, should at least be considered.
The Canon wireless may be "line of sight" but indoors, (or at very short range outdoors), it works very well without direct line of sight.
liupublic
Apr 17, 2011 12:49 |  #8
If going with ST-E2, Yongnuo version is better than the Canon version because Yongnuo version can rotate a bit to aim toward the bracket. Then rotate the 580EXII so the receiver is facing the ST-E2. This will solve the line of the sight problem.
Still learning
gonzogolf
Gallery: 559 photos
Apr 17, 2011 19:13 |  #9
I agree with Mike, rather than spend additional for an accessory upgrade the OP could get it in a new camera with all the additional benefits of new technology. While the simple answer is get a better cord and learn to live with it, if the goal is wireless the that solution is as good as any.
RPCrowe
Joined Nov 2005
Apr 17, 2011 19:32 as a reply to  @ gonzogolf's post |  #10
I have just experimented with my 7D using a 420EX flash on an off-camera bracket and shooting outdoors.
When shooting with the sun behind me, the 7D fired the flash even though there was not a nearby subject in the frame. It did not fire the flash when shooting into the sun until I placed a subject in the frame. However once I placed my mannequin head about 6-8 feet from the camera in the frame, the 7D fired the flash wirelessly. I did not experiment to see how far I could get from the head and still have the 7D fire the camera.
I like not having an off camera cord between camera and flash since the module on which the flash sits produces extra torque on the flash foot which I can anticipate causing damage if I moved fast. The feet of the earlier Canon flash units are made of plastic while later flashes have (I believe) metal feet.
ShotByTom
Gallery: 23 photos
Apr 18, 2011 00:45 |  #11
RPCrowe wrote in post #12241711 (external link)
I've been using the ocf cord on a bracket for weddings and have never had a problem with it. I've banged the flash on door frames and chairs and even dropped the whole rig and have never had a flash break off. I've been afraid of breaking it too, so I usually use the 580 on the bracket, because it would be cheaper to replace than the EX II version, but I've never had a problem with it.
Gear
Website (external link)
windpig
Chopped liver
Apr 18, 2011 06:55 |  #12
This is a much debated topic. Everybody has had different experiences.
Mine:
3 OCF chords that went south almost immediate, one of which came apart the first time I pushed the flash on the end.
7D that did not quit live up to my expectations as flash commander
ST-E2 that actually works better than I expected and also works well for low light AF support.
I would love to try out the 3 party unit, not that I would buy one.
The Radio Popper ETTL unit intrigued me, but I didn't really like the DIY feel to it with the sensor thingies and cost.
I almost considered PW's, but RFI issues with the 580's and cost.
Badfisherman
Apr 25, 2011 15:55 as a reply to  @ windpig's post |  #13
I am curious about small flash, bracket type I guess. Pics of these set ups would be very useful for me.
windpig
Chopped liver
Apr 25, 2011 16:08 |  #14
Badfisherman wrote in post #12290692 (external link)
What are yoy trying to do?
gonzogolf
Gallery: 559 photos
Apr 25, 2011 16:19 |  #15
Other than wedding or event work brackets aren't particularly useful. They get your flash off the camera, but really only far enough to direct the shadows slightly downward and to allow you to shoot vertical while keeping the flash properly oriented.
2,481 views & 0 likes for this thread, 9 members have posted to it.
1384 guests, 179 members online
