I posted this on an existing thread, but never got any response. Is there anything I can do about glare on glasses when using a speedlight?
firemanjd Member 175 posts Joined Mar 2011 Location: North Carolina More info | Apr 17, 2011 18:40 | #1 I posted this on an existing thread, but never got any response. Is there anything I can do about glare on glasses when using a speedlight? Gear: 60D Canon EF-S 18-135mm , EF 50mm 1.8f II, 2 - 430ex Speedlights, an old cheapo tripod, and a Kata R-103 bag.
Slaterza Goldmember 2,007 posts Likes: 7 Joined Nov 2007 Location: Beijing, China More info | Apr 18, 2011 05:35 | #2 Have the subject tip their head down just a bit, or move the speedlights (higher or wider) so that angle of light doesn't hit the glasses, or remove the lenses. In this particular pose I would have had the subject tilt their head down just a touch and also might have moved my shooting angle slightly. Sam Laterza flickr
Apr 18, 2011 06:32 | #3 Thanks. The subject is my daughter, so I'll put her to work modeling again in the next day or so to see if I can figure it out. Gear: 60D Canon EF-S 18-135mm , EF 50mm 1.8f II, 2 - 430ex Speedlights, an old cheapo tripod, and a Kata R-103 bag.
checkgio Senior Member 379 posts Joined Apr 2009 More info | Apr 18, 2011 13:52 | #4 I believe if her head was tilted a little more to her left, the glare wouldn't have reflected back to the camera. Here is a very useful tutorial from Strobist. I definitely recommend doing the Lighting 101 and 102. It will teach you so much.http://strobist.blogspot.com …lighting-for-glasses.html
May 27, 2011 20:59 | #5 Here's my attempt at getting rid of the glare. I know it's not that great, but I think it's an improvement. Gear: 60D Canon EF-S 18-135mm , EF 50mm 1.8f II, 2 - 430ex Speedlights, an old cheapo tripod, and a Kata R-103 bag.
May 27, 2011 21:09 | #6 You can also move the temple pieces up just a hair above her ears and that will give you the same effect as head tilt. You'd never notice in the image as it's very subtle.
JMartel Goldmember 1,307 posts Likes: 1 Joined Dec 2009 Location: Seattle, WA More info | May 27, 2011 21:13 | #7 |
windpig Chopped liver More info | May 27, 2011 22:16 | #8 Have her face a little more away from the light, not much. Would you like to buy a vowel?
May 29, 2011 20:59 | #9 I think it goes without saying, but that was my PP attempt at glare removal. Gear: 60D Canon EF-S 18-135mm , EF 50mm 1.8f II, 2 - 430ex Speedlights, an old cheapo tripod, and a Kata R-103 bag.
| Latest registered member is MWCarlsson 954 guests, 183 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
