what do you suggest......?
I know If I go with the Filter it needs to be a good one
have a few L lens now and looking to protect my investment
bckane Senior Member 885 posts Joined Mar 2007 Location: Miramar, Fla More info | Apr 17, 2011 18:44 | #1 what do you suggest......? Brian
Apr 17, 2011 18:50 | #2 Hood. Always. There's really no downside to using them. If you insist on getting a UV filter, get an expensive multicoated one from a top brand like B+W.
lungdoc Goldmember 2,101 posts Likes: 1 Joined May 2006 Location: St. Catharines, Ontario Canada More info | Apr 17, 2011 18:55 | #3 Everybody agrees on hoods. Tons of threads on filters, some favor them, some don't. As stated if you use one use a good one (can be just clear as UV doesn't affect digital). I personally use when splashes or grit more likely to be issues, not most of the time. Mark
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Apr 17, 2011 18:55 | #4 I have and use both, on every one of my lenses at all times. [Gear List | Flickr
Bokehlicious Senior Member 809 posts Joined Jan 2011 More info | Apr 17, 2011 18:58 | #5 Hoods are more beneficial than filters but I still use both.
Monito Senior Member 460 posts Likes: 2 Joined Jan 2005 Location: Halifax, NS, ex-California More info | Apr 17, 2011 18:59 | #6 A hood always improves a photo and protects the lens. Canon System: fullframe DSLRs, lenses. Tripods, Alien Bees.
Apr 17, 2011 19:05 | #7 Thanks for the input Brian
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Apr 17, 2011 19:16 | #8 I use both. Conditions I'm going to be in tend toward the unpredictable and hoods aren't the be-all and end-all of protection. Jon
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 17, 2011 19:34 | #9 A hood reduces flare.
A filter modifies the light striking the film/sensor.
In other works, other than the primary purpose of a hood or a filter, its secondary goal of 'mechanical damage protection' is only sometimes true, and sometimes UNtrue! NEITHER are the be-all and end-all of protection. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
BroncoAZ Senior Member 393 posts Joined Jun 2009 Location: Scottsdale, AZ More info | Apr 17, 2011 19:37 | #10 I use quality UV filters for protection and hoods to reduce flare when necessary. Unless I anticipate flare or other lighting concerns I seldom fit the hood. Canon 60D, Canon 17-55mm f/2.8, Canon 70-200mm f/4L IS, Canon 10-22mm, Canon Extender EF 1.4x II, Canon 430EX II, B+W MRC filters, Pelican 1450 with dividers, Think Tank Digital Holster 10V2, 2011 Macbook Pro 15" i7 2.0 GHz 8GB RAM, Canon D10
RPCrowe Cream of the Crop More info | I fell to the concrete with my 40d and 70-200mm f/4L IS lens around my neck. The lens was wearing a hood (in this case a round screw-in generic hood) which hit the concrete first. The hood was toast but the lens came through unhurt. I attribute the saving of the lens to the hood which broke and absorbed the kinetic energy of the impact; just like the body of a NASCAR vehicle absorbs the impact of a crash by breaking apart. See my images at http://rpcrowe.smugmug.com/
DANATTHEROCK Goldmember 1,264 posts Joined Apr 2008 Location: North Carolina More info | Apr 17, 2011 21:11 | #12 Jon wrote in post #12241636 I use both. Conditions I'm going to be in tend toward the unpredictable and hoods aren't the be-all and end-all of protection. Same here and as said earlier, get a high quality clear/UV filter if you get one. I use the Hoya Pro 1 and HD and can't tell a bit of difference on images with and without them. If they degrade the image, I can't see it. I also use hoods for protection and other reasons. Canon 5D Mark II & 50D with 17-40, 24-105, 100-400, 50 f/1.4, 100 f/2.8 macro, and 1.4TC
K&K_Dad Member 194 posts Joined Dec 2010 Location: USA, Earth More info | Apr 17, 2011 21:47 | #13 I'm another in the both category. Filter because I just don't trust anyone and I'm always afraid that dirt or rocks are coming my way(kids will managed to do that to you). and hoods to keep things from getting close. My Photstream @ FlickR
windpig Chopped liver More info | Apr 17, 2011 22:18 | #14 Unless I'm on a beach with the wind blasting or something that abusive, I'll find my hood to be just fine. Would you like to buy a vowel?
Jericobot Cream of the Crop 5,128 posts Likes: 1 Joined Jun 2010 Location: preppingforthetrumpets More info | Apr 18, 2011 02:04 | #15 Both used, original canon hoods and b+w mrc slim filters. Just for extra peace of mind α7ii + (batis 25 f2 / zeiss 55 f1,8 / macro 90 f2,8)
| Latest registered member is MWCarlsson 913 guests, 182 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
