Will this also fit a 580ex II???
JamieMc83 Senior Member 293 posts Joined Nov 2010 Location: Corinth, MS More info | Apr 18, 2011 09:31 | #1 Will this also fit a 580ex II??? ~Jamie
msowsun "approx 8mm" More info | May 04, 2011 21:38 | #2 EDIT: I just picked up a used Canon Compact Battery Pack E and tried it with my 580 EX II. It works very well. The CP-E2 is a modified version of the original Compact Battery Pack E. It improves flash recycle times significantly and increases the number of firings before batteries need to be replaced. This version accepts six "AA" size batteries; lithium, alkaline, as well as rechargeable NiCd's or NiMH. CP-E3 is a new design with 8 AA batteries instead of 6 AA batteries. Updated from the earlier version, the CP-E3, the CP-E4 has been improved with better dust and moisture sealing at the contact points, to get it to match the weather-resistance characteristics of the 580EX II Speedlite. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member was a spammer, and banned as such! 2674 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
