Thread started 18 Apr 2011 (Monday) 14:21
RAW and LR
pwilliamson
Joined Mar 2011
Apr 18, 2011 14:21 |  #1
Hi folks,
I've starte editing all my photos in RAW and have a few questions about getting the best detail in my final work. Is tiff the best format to save the final copy into? Will photo printing places print this format? If I'm going to edit in cs5 after lightroom should I be saving in psd format so there is no loss and then save the final to tiff/jpg in cs5?
Canon 5D MK3 | EF 24-105mm f/4L IS | EF 100mm f/2.8L IS | EF 70-200 f2.8L IS II | EF 400mm f5.6L | Canon 580EX II | Canon 430 EX II | Kenko Extension Tubes
>>> WWW.FLICKR.COM/PWILLIA​MSON (external link) <<<
tonylong
...winded
Gallery: 60 photos
Apr 18, 2011 15:13 |  #2
When you are in the process of working with your images, it can be considered "best practice" to keep your images in "high quality" files, so the tiff or psd formats are best for that, rather than jpegs which have been compressed in two different ways. Your tiffs can be either 16 bit, which have the fullest range of image data, and CS5 can work well with them up to a certain point, or 8 bit, which you can eventually convert to and have a smaller file size.
Your final output can be saved as a jpeg for print or other uses. For printing some labs will accept a tiff, but if you save a full size high quality jpeg as a final product you really won't see a problem. People run into problems with jpegs when they either save one multiple times, causing multiple compression episodes, or they over-compress and then try to get a large print.
Tony
pwilliamson
Joined Mar 2011
Apr 20, 2011 03:25 |  #3
Thank you so much for the info!
1,093 views & 0 likes for this thread, 2 members have posted to it.
RAW and LR
2714 guests, 168 members online
