That's, what's your Actuations Per Year? I've had my G11 for a year this month and I'm at 4477, or about 373 per month.
To find your APY...worked in my G11 not sure about others
You'll need a PC with a SD card reader.
Put the card in the reader, and create a new, empty file named VERS.REQ at the root level of the data card. (e.g. if the drive letter the reader uses for the card is "G:" then the file will be G:\VERS.REQ and not G:\DCIM\VERS.REQ or anything else.)
Put the card back in the G10, then start in Preview mode
Hold down the SET button and press DISPLAY
The Firmware Version and other info is shown.
Repeat the above step 2 more times.
The second screen displays some more internal version info.
The THIRD screen shows an item "Total Shoot:" followed by a number. The number is the total number of shots by the camera.
You can use notepad or other basic text editor to create the file VERS.txt
then exit out of notepad, right click on the file and choose rename, then change the extension to req, drag and drop into the SD card and your done
