Thread started 18 Apr 2011 (Monday) 20:07
cropping and prints
Nickc84
Apr 18, 2011 20:07 |  #1
I was wondering how to crop an image correctly so when you make prints they come out normal?
ssim
Joined Apr 2003
Apr 18, 2011 20:43 |  #2
Select your crop tool and input the sizes and resolution that you want. This example is one for an 11x14.
IMAGE: http://www.pbase.com/ssim/image/104492829.jpg
You should check with your lab to see if they provide a custom profile so that you can apply that. If you are doing local printing by yourself it is a good idea to check the paper manufacturer's website to see if they provide a profile for your printer.
Nickc84
Apr 18, 2011 23:06 |  #3
if your sending them out to get printed professionally do I have to worry about this or just give them high quality JPEG?
tzalman
Fatal attraction.
Apr 19, 2011 05:14 |  #4
1. The image should always be the same shape as the paper it will be printed on. E.g., if you order an 8x10 print, that paper has a 4:5 ratio, so your image should be cropped to that ratio.
2.If you divide the number of pixels in a side of your image by the length of the same side of the print (in inches) the result should be no less than 180. That number is known as ppi - pixels per inch. 300 ppi gives best quality, more is overkill but ok, and anything less down to 200 ppi will range from good to acceptable.
3. Unless the lab specifically requests a different color space, the image must be in the sRGB space.
Elie / אלי
566 views & 0 likes for this thread, 3 members have posted to it.
cropping and prints
2844 guests, 166 members online
