Thread started 19 Apr 2011 (Tuesday) 03:22
DPP 3.10.1 up on Canon UK site
iriches
Apr 19, 2011 03:22 |  #1
Link:
http://www.canon.co.uk …5654&page=1&typ​e=download (external link)
The "Accept and download button" is right at the bottom of that page.
From the above page:
Changes for Digital Photo Professional 3.10.1 Updater for Windows;
1. Support added for images taken with the EOS Kiss X50 / EOS REBEL T3 / EOS 1100D, EOS Kiss X5 / EOS REBEL T3i / EOS 600D.
If using an earlier version, images take with the EOS Kiss X50 / EOS REBEL T3 / EOS 1100D, EOS Kiss X5 / EOS REBEL T3i / EOS 600D will not be supported. Please update to version 3.10 or later.
2. Additional lenses now covered by correction of lens aberration. Including overseas models, images taken with the following six lenses are now covered by lens aberration correction.
EF 8-15mm F4L USM Fisheye, EF 15mm F2.8 Fisheye, EF 300mm F2.8 II IS USM, EF 400mm F2.8 II IS USM,
EF-S 18-55mm F3.5-5.6 III (an overseas model), EF-S 18-55mm F3.5-5.6 IS II
Distortion aberration correction for images taken with fisheye lenses (EF 8-15mm F4L USM Fisheye, EF 15mm F2.8 Fisheye) enables the user to select four types of effects that are not covered by ordinary distortion correction.
Note that depending on the camera used, there are cases where images taken with applicable lenses may not be covered by aberration correction.
3. Added a function for circular masking. The new Circle option can be selected from the Ratio pull-down menu for the Trimming/angle adjustment tool. The behavior differs from when rectangles like 1:1 are selected in that selecting Circle will masking everything outside of the selected area.
4. When performing Noise Reduction processing, there were cases where the screen would momentarily turn magenta.
5. Fixed a malfunction involving PCs on which multiple versions of Photoshop are installed; there were cases where the Transfer to Photoshop command would be dimmed.
6. Fixed a malfunction in which attempting to display NR Preview while the highlight warning was displayed would cause the Preview screen to turn deep blue.
7. Fixed a malfunction that occurred if an image was overwritten by a newer version after a rating had been set; there were cases where the editing results were destroyed and the image reverted back to the settings when it was first taken.
8. Fixed a malfunction wherein white lines would appear in the displayed results if an image was displayed at 100% in the Edit Window or the Edit Image Window and the window was then scrolled.
9. Windows XP SP2 is no longer supported
If using this software in a Windows XP environment, please update Windows to Service Pack 3 before installing the software.
Ian Riches - Bedford, UK.
EOS 40D | EOS 50e
| EF-S 17-85 f/4-5.6 IS USM | EF 28-70 f/3.5-4.5 | EF 100-300mm f/4-5.6 USM | EF 50 f/1.8 II | 420EX
yb98
Joined Feb 2003
Apr 19, 2011 03:57 |  #2
Thanks !
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
mrkgoo
Apr 19, 2011 06:55 |  #3
Does it matter what country site we download these from? I live in NZ (and my computer - Mac - is set to NZ, but I got my camera from the US.
iriches
Apr 19, 2011 06:57 as a reply to  @ mrkgoo's post |  #4
No. I'm in the UK, but in the past have successfully downloaded & installed from US and Asian Canon sites.
EOS 40D | EOS 50e
mrkgoo
Apr 19, 2011 07:02 |  #5
iriches wrote in post #12251515 (external link)
Nice. Thanks!
iriches
Apr 19, 2011 07:05 as a reply to  @ mrkgoo's post |  #6
Just noticed you're on a Mac. I use PC - so there may be a difference.
BTW, my link was to the PC version. The Mac one is here:
http://www.canon.co.uk …5652&page=1&typ​e=download (external link)
EOS 40D | EOS 50e
yb98
Joined Feb 2003
Apr 19, 2011 07:37 |  #7
I'm wondering why they added this circle masking ?
What's the benefit of that ?
Or are they preparing something like U-Points ?
Best DPP Threads
iriches
Apr 19, 2011 07:43 |  #8
yb98 wrote in post #12251631 (external link)
I'm guessing it's something to so with:
"Distortion aberration correction for images taken with fisheye lenses (EF 8-15mm F4L USM Fisheye, EF 15mm F2.8 Fisheye) enables the user to select four types of effects that are not covered by ordinary distortion correction."
A circular mask could prove quite handy with a fisheye?
EOS 40D | EOS 50e
PeterWem
Apr 19, 2011 09:20 |  #9
Feels like a bug in DPP3.10.1. When changing between the folders it takes like 2-4 seconds before I can see any images. DPP freeze in this time and loading for nothing. Where do I report this bug to Canon?
Windows 7 64.
I am going to install DPP3.9.4 again.
whiteflyer
Gallery: 314 photos
Apr 21, 2011 05:47 |  #10
PeterWem wrote in post #12252135 (external link)
Windows 7 64.
No problem here with Mac OS X 10.6.7 running in 64 Bit mode, just glad Canon have at last sorted the problem they had with moving files to different folders that was in OS X.
iriches
Apr 21, 2011 05:58 |  #11
Windows 7 64.
No problems for me with either Win 7 32-bit or Win XP. There is a brief pause on clicking on a new folder - linked to how many images are in that folder - but it's not struck me as different to any previous version.
EOS 40D | EOS 50e
bohdank
Apr 21, 2011 06:54 |  #12
Seems to run fine Win 7 x64
PeterWem
Apr 21, 2011 17:54 |  #13
iriches wrote in post #12265000 (external link)
Like that, yes. But for me 1-4 seconds in some folders. Random. Could be like 3 pictures in the folder or 300.
6,216 views & 0 likes for this thread, 6 members have posted to it.
1537 guests, 168 members online
