Silly me but I thought by using Canon OC-E3 cable, it allows you to get higher shutter speed above 5D II of 200 and 7D of 250 on manual mode.....
Or am I wrong?
mchong75 Goldmember 2,927 posts Likes: 5 Joined Jun 2007 Location: Frisco, TX More info | Apr 20, 2011 10:19 | #1 Silly me but I thought by using Canon OC-E3 cable, it allows you to get higher shutter speed above 5D II of 200 and 7D of 250 on manual mode..... (Michael) Gears:
TheLoftStudios Goldmember 1,072 posts Likes: 9 Joined Oct 2009 Location: Houston, Texas More info | Apr 20, 2011 10:27 | #2 Yes and No.... MARK
gonzogolf dumb remark memorialized More info | Apr 20, 2011 10:27 | #3 It just extends the hotshoe, and it doesnt change sync speed unless you have the flash set in HSS.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Apr 20, 2011 11:24 | #4 Yep, like everyone else already said, it does nothing but allow you to get the flash off the camera a little bit. Otherwise the flash should function exactly like it normally does when attached to the hotshoe directly. [Gear List | Flickr
| Latest registered member was a spammer, and banned as such! 2839 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
