This is a link to a macro mode shot of crocus I posted in the nature thread.
https://photography-on-the.net …/showthread.php?t=1027931
Apr 21, 2011 01:07 | #1 This is a link to a macro mode shot of crocus I posted in the nature thread. Comments, Questions, Observations Welcome
JohnBaker Senior Member 480 posts Likes: 3 Joined Sep 2006 Location: Teignmouth, Devon, UK More info | Apr 21, 2011 01:34 | #2 It is very effective and gives a totally different perspective and look, you would really struggle to get anything like it with a traditional DSLR – the only slight disadvantage is the working distance, which means you need to get up close and personal to use at the wide-angle end. Great for flowers, but not so good when you are trying to sneak up on a bug, where they start to feel you are getting too close… John Baker
Apr 21, 2011 08:49 | #3 John Baker wrote in post #12264423 Great for flowers, but not so good when you are trying to sneak up on a bug, where they start to feel you are getting too close… Yes, nice for flowers, and when you are traveling light without adapter tubes and close-up lenses. However, some creatures will "pose" for you; IMG_4673x2r Taken with my G11, and camera moved slowly to within inches of this fellow. Dennis
Apr 21, 2011 09:15 | #4 Absolutely. You must use the wide angle perspective. Comments, Questions, Observations Welcome
Apr 21, 2011 11:05 | #5 I like that lazy lizard. Comments, Questions, Observations Welcome
Johnotford Mostly Lurking 16 posts Joined Jul 2010 Location: Sevenoaks, UK More info | Apr 21, 2011 12:00 | #6 |
Johnotford Mostly Lurking 16 posts Joined Jul 2010 Location: Sevenoaks, UK More info | Apr 21, 2011 12:53 | #7 |
JohnBaker Senior Member 480 posts Likes: 3 Joined Sep 2006 Location: Teignmouth, Devon, UK More info | Apr 21, 2011 14:27 | #8 Some really great work being posted - love the mouse and the tulip... One from me taken earlier in the week. John Baker
Johnotford Mostly Lurking 16 posts Joined Jul 2010 Location: Sevenoaks, UK More info | Apr 21, 2011 14:40 | #9 Thanks for your comments, John. Your shot really is excellent. Did you use a Raynox or other close up lens? I have a Raynox DCR-250 but can never see the screen clearly enough to focus as well as that.
defante Senior Member 378 posts Likes: 9 Joined Apr 2011 More info | Apr 21, 2011 15:48 | #10 I agree with plants being easier. Here's one with my new achromat. Dandelion
JohnBaker Senior Member 480 posts Likes: 3 Joined Sep 2006 Location: Teignmouth, Devon, UK More info | Apr 21, 2011 17:30 | #11 Johnotford wrote in post #12267514 Thanks for your comments, John. Your shot really is excellent. Did you use a Raynox or other close up lens? I have a Raynox DCR-250 but can never see the screen clearly enough to focus as well as that. John Hi John, I did use a close up lens, but it was a +1.6 dioptre, which is not as strong as yours. John Baker
Apr 21, 2011 17:44 | #12 Maybe we should change the title to Post Your G Macros... ! Comments, Questions, Observations Welcome
Johnotford Mostly Lurking 16 posts Joined Jul 2010 Location: Sevenoaks, UK More info | Apr 22, 2011 03:27 | #13 John Baker wrote in post #12268390 Hi John, I did use a close up lens, but it was a +1.6 dioptre, which is not as strong as yours. It means I have a working distance of around 60cm/23 inches (I will put the imperial measure as well!!) – remember the way to work this out is based at infinity, a close up filter will focus at a fraction of 1 meter/40 inches, so a +1 dioptre filter will focus at 100/1 so 1 meter or 100cm or 40 inches, a +2 is 100/2 so you are down to 50cm/20 inches, a +4 is 100/4 = 20cm/8 inches. The Raynox DCR250 is a high quality product, but it is a +8 which is a lot stronger and means you will have a working distance of around 12cm or 5 inches, which is not a lot. The stronger the filter (e.g. higher the dioptre) the harder it is to use and the less depth of field you will get, I always recommend getting a low dioptre to start, remember you can stack filters so if you have a +1 and a +2 you can add them together to make a +3. The other issue with the stronger filters is that you can end up working in your own light an getting extra light in adds to the challenge… Many thanks for your advice, John.
Fruitzilla Member 39 posts Joined Feb 2011 Location: Utrecht, The Netherlands More info | Apr 22, 2011 08:53 | #14 |
bogeypro Senior Member 335 posts Likes: 19 Joined Dec 2010 Location: Western NY More info | I've got a Canon 250D 58mm lens, pristine glass, if anyone is interested.
| Latest registered member is semonsters 923 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
