is the whibal significantly more accurate?
hence, is it worth the money over a kodak grey card?
i dont want to feel like im being suckered into buying one because they claim its much more accurate.
iwasinvertedx Senior Member 718 posts Joined Mar 2009 Location: Los Angeles, CA More info | Apr 22, 2011 00:47 | #1 is the whibal significantly more accurate?
Apr 22, 2011 07:36 | #2 The camera pre-sets for white balance are pretty good but setting a custom white balance using an 18% gray card is more accurate. Most folks on this forum seem to prefer adjusting WB in PP but I get a lot satisfaction from getting it right in the camera. 7D, 50 f1.8, 17-55 f2.8, 70-200 f2.8 II, 100-400 f4.5-5.6L, 2x TC III, 580EX II, 430EX, 568EX II, 622C
TimSnow Member 231 posts Joined May 2007 Location: Montreal More info | Apr 22, 2011 07:53 | #3 I have and use a Whibal, especially in lighting situations that don't change or where having the proper color is extremely important, usually product shoots. 1dMkIII, 5dMkII, 16-35, 24-70, 70-200 f/2.8IS II, 15mm fish, 24 1.4, 50 f/1.4, 135 f/2, 580 II, 550, PW Mini's Flex's and Plus II's, Think Tank AI V2.0, Think Tank Skin, Alien Bees -
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Apr 22, 2011 08:15 | #4 For me, the WhiBal cards are better than the Kodak cards for color balance reference for two reasons. One is the ability to prop the cards up with the provided stands. The other is that the color of the WhiBal product is uniform through the entire thickness of the product. If I smeared something on a WhiBal card, I could scrub it off and wind up with surface still being the proper color. Skip Douglas
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Apr 22, 2011 12:11 | #5 I use this guy: LINK [Gear List | Flickr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 22, 2011 19:25 | #6 Apart from questions of material durability, the WhiBal and the Kodak card are going to give you perfectly nuetral gray for WB setting. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
You-by-Lou Goldmember 1,691 posts Likes: 7 Joined Aug 2011 Location: Manhattan More info | Aug 05, 2011 16:46 | #7 A question. When taking the picture of either the grey kodak card or the white balance lens cover....what setting do you have the camera's white balance set to? You may say I'm a Zoomer, But I'm not the only one
jrsforums Goldmember 1,249 posts Joined Feb 2005 Location: Cary (Raleigh), NC, USA More info | Aug 05, 2011 18:56 | #8 Lou857 wrote in post #12884113 A question. When taking the picture of either the grey kodak card or the white balance lens cover....what setting do you have the camera's white balance set to? I just realized I've been setting it from the previous setting. is "AWB" the place to be when setting CWB? Thank you. If you are shooting jpeg, you should set a CWB. John
YankeeMom Goldmember More info | Aug 05, 2011 19:13 | #9 I have a Whibal card and found that it didn't work well for me, so I've been adjusting WB in PP. Not sure if I'll try it again. I definitely should have saved the $$. Kristin
Aug 05, 2011 19:22 | #10 Whibal cards make a world of difference inside with available light. I don't think I've tried using it outdoors. I think I read somewhere to use the Tungsten setting for sunrise/sunset photos. 7D, 50 f1.8, 17-55 f2.8, 70-200 f2.8 II, 100-400 f4.5-5.6L, 2x TC III, 580EX II, 430EX, 568EX II, 622C
jrsforums Goldmember 1,249 posts Joined Feb 2005 Location: Cary (Raleigh), NC, USA More info | Aug 05, 2011 20:41 | #11 GeeMack wrote in post #12884690 I think I read somewhere to use the Tungsten setting for sunrise/sunset photos. Let me make a suggestion. Find a good sunrise/sunset....shoot at each of the WB settings....also try a CWB with the Whibal....then see which you like. John
MCAsan Goldmember 3,918 posts Likes: 88 Joined Jun 2010 Location: Atlanta More info | Personally I don't need an accurate reproduction of the scene. I don't do product or documentary photography.
You-by-Lou Goldmember 1,691 posts Likes: 7 Joined Aug 2011 Location: Manhattan More info | Aug 06, 2011 06:41 | #13 jrsforums wrote in post #12884606 If you are shooting jpeg, you should set a CWB. If you are shooting RAW, you can set a CWB, but do not need to. In the RAW conversion, use the eyedropper to use the greycard to set the WB. Remember....this is ONLY a starting point. You will need to adjust it to get the look that you saw with your eye (or in your mind's eye). For example, if you set a CWB/WB with a greycard of a beautiful golden sunset....you will not get a golden sunset. The real key is knowing when you need to use a greycard and when you don't. Thanks. You may say I'm a Zoomer, But I'm not the only one
Csae Goldmember 3,350 posts Likes: 1 Joined Nov 2008 Location: Montreal, Canada More info | Aug 06, 2011 21:39 | #14 YankeeMom wrote in post #12884663 I have a Whibal card and found that it didn't work well for me, so I've been adjusting WB in PP. Not sure if I'll try it again. I definitely should have saved the $$. +1 Feel free to call me Case.
windpig Chopped liver More info | Aug 06, 2011 22:32 | #15 I've got an use both the WhiBal and Xrite Passport. Would you like to buy a vowel?
| Latest registered member is johntmyers418 1049 guests, 185 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
