So I THINK this will work, but wanted to throw this out at you guys.
I own the Cheetah Speed Pro Bracket, along with my 430EXII Speedlight. Here's a pick of the bracket:
http://www.cheetahstand.com …-Speed-Pro-Bracket/Detail![]()
as you can see in the 3rd pic, it has an umbrella holder - and being the Speedlight is layed flat, it should fit right into the Softlighter II sock, right?
So I want to use that, along with the Softlighter II:
http://www.bhphotovideo.com …rella_Softlighter_II.html![]()
Should work, right? Fit the sock over the Speedlight head, and I should be good to go, right? Can anyone confirm?
Also - do you think with the 430EXII speedlight - should go with the 46" or 36" ? I want the max softness/spread, but don't want to loose efficiency.
