Thread started 23 Apr 2011 (Saturday) 10:35
manfrotto 498rc2 help me ,please
mantra
Apr 23, 2011 10:35 |  #1
hi
last night i was taken shoot with my manfrotto with a 498rc2 ball head
well i was a fool and absent minded and i did completely unscrew the ball knob , it did fall to the ground
it did fall to the ground a small steel pin,luckily in the darkness i found it
i tried to fix it again in the darkness , and the pan knob did fall to the ground too
yes i know i'm dupe
now may i ask you your help ?
1) for the ball knob , i did put the steel pin inside the hole of the ball head with large edge deep inside and i did screw the know
did i do it correctly ?
2) for the pan know i did not find a steel pin or other parts but only the knob with a flat ends , i did screw it
did i do it correctly ? or did i loose some small pieces/parts ?
thanks
in the spare part there is nothing about this -> pdf http://mediacdn.shopat​ron.com …2_20090616.pdf?​1291225281 (external link)
is there a way to make the the head rotate more fast ?
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
mantra
Apr 23, 2011 23:22 |  #2
to clarify ..
Hi
to clarify my horrible english
1) when the ball knob has been dropped , i found 2 separate pieces
the ball knob and a small steel pin
in short in the night i found on the ground first the ball knob and after 20 minutes the steel pin
i had to mount them, and i did not how do it
2) the pan knob has been dropped tooo , i found the pan knob but not the steel pin for it
i don't know if the pan knob needs to work the small steel pin
1,071 views & 0 likes for this thread.
1053 guests, 103 members online
