Thread started 24 Apr 2011 (Sunday) 08:51
Constant or strobe for product photography?
cameraperson
Apr 24, 2011 08:51 |  #1
I was trying a little experiment with product photography for microstock. Is it better to use continuous lights for that type of picture or flash? I saw a video on pro photo life that used a diffused shop light (which is what I did) but wanted other opinions.
Xsi, 18-55
sempaidavid
Apr 24, 2011 10:06 |  #2
Constant light is much easier to use in my opinion. You can see exactly what you will get. It is also much easier to position your flags.
5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
http://www.davidcostap​hotography.com (external link)
Austin.Manny
Apr 24, 2011 11:20 |  #3
I use flash, personally, but in your case I would probably go continuous light + a tripod. Keep in mind though, microstock is a very demanding field. Every little detail counts.
1D Mk III | 450D Gripped | Σ 30 f/1.4 | 85 f/1.8 | 18-55 IS
Canon 430exIII | LumoPro LP180 | Yongnuo YN-460 |
RF-603
SuperHuman21
Apr 24, 2011 11:26 |  #4
Strobe. Use the modeling light and you've got both of these in one.
D90, 105mm f/2.8, 18-105mm DX, D-Lite 2 it (3), 32" Photoflex softbox (2), Manfrotto 3021BN w/3047 head
Arthur
-Stones and Jewelry Photographer-
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 24, 2011 21:54 |  #5
SuperHuman21 wrote in post #12283236 (external link)
That's a good option & generally leads to a cooler studio environment.
Personally, for product, having used incandescent lights from 100wt to 20,000 wt with focusing fresnel lenses (external link), I lean toward them. I just feel that I have more control with them.
SuperHuman21
Apr 24, 2011 23:26 |  #6
PhotosGuy wrote in post #12286115 (external link)
Yes, I do agree with you on that in theory (only because I've never tried this before). I thought the same thing but went for strobe because a beginner will have so much to learn that he'll get dizzy. I've been thinking about how to have more control with my lights and then add a few more lights to that. I'm guessing flags will be my best bet?
Arthur
anlenke
Joined Mar 2011
Apr 24, 2011 23:28 |  #7
Food can be tricky; hotlights (constants) can literally melt it. I like using strobes with hotlights, or LED light panels which won't overheat anything.
Hi. I'm Anton.
Personal work: Flickr (external link)
Gear, for those who want to know.
PhotosGuy
Joined Feb 2004
Apr 25, 2011 08:34 |  #8
Flags, grids, focusing spots, cardboard "flats"...
Look at the knife & Browning threads here for some ways to get interesting lighting:
FAQ - Studio Lighting
One of them shows an example using just one light source.
Wilt
Apr 27, 2011 18:02 |  #9
Typically you need really deep DOF for product photography, and that is best accomplished with the use of high power strobes. Contstant lights would need very long exposures to accomplish proper exposure with small f/stops! Studio strobes' modelling lights provide the constant, visible effects to optimize light placement with minimal time, while the high output permits use of small apertures without the heat of high output constant lights.
Savas ­ K
Apr 27, 2011 19:59 |  #10
Just don't use hot lights to shoot ice cream.
ssim
Joined Apr 2003
Apr 28, 2011 03:34 as a reply to  @ Savas K's post |  #11
When I first started in photography I used continuous hot lights as they were alot more affordable. I now use nothing but strobes and you will find that with a little practice and experience you would not regret going this way. As was noted above, use your modelling lamp if you are worried about your shadows.
6,222 views & 0 likes for this thread, 9 members have posted to it.
2744 guests, 165 members online
