Thread started 25 Apr 2011 (Monday) 08:36
Do I need an On-Camera Flash to Maintain Focus Assist?
Peacefield
Apr 25, 2011 08:36 |  #1
I'm considering a new approach to flash for dark wedding receptions. Instead of my current approach of either bouncing or using two flashes via infared in ETTL, I'm thinking 2-3 monolights around the perimeter bounced into the corner of the ceiling to bring up ambient controlled by Cybersyncs and main lighting by an off-camera flash in manual with some kind of modifier, also via Cybersyc.
My questions mostly have to do with focus assist and the modifier. I'm looking at some collapsible softboxes. I also have a 22" white shoot through umbrella.
I'd obvioulsy have the Cybersync transmitter in the hotshoe. With that approach, I assume there's no focus assist from the remote flash since there's no way to communciate that info? If I do, won't the modifiers block it?
Or do I not get focus assist and need to have an on-camera flash set to disabled just for the focus assist? If so, how would I mount the non-firing on-camera flash and the Cybersync transmitter?
Thanks.
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
CiM_Photography
Joined Sep 2009
Apr 25, 2011 08:44 |  #2
The shoe-mounted flash (being used for infrared beam assist) would need to have a sync port so you can hook up the transmitter responsible for telling your lights to fire.
And no - your mono-lights will not assist you in focusing.
Another alternative is to invest in triggers that have the "pass-through" ability, such as the Cactus V5.
Just call me Jeremy. <Massachusetts Wedding & Portrait Photographer (external link) | Gear List>
bobbyz
Apr 25, 2011 08:57 |  #3
Flash or Ste on camera hot shoe and CST to your sync port. Or passthrough triggers like already mentioned. I would prefer mini/flex with ABs or just the flashes as remote lights so that I can control the power as well as turn them on/off from camera location using AC3.
Fuji XT-1, 18-55mm
Red ­ Tie ­ Photography
Apr 25, 2011 19:01 |  #4
CiM_Photography wrote in post #12288055 (external link)
From what I have learned/experienced, the Cactus V5 does not offer pass-through. If it does, do you mind filling me in on how to do it? This is one of my biggest gripes with the Cactus v5.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
CiM_Photography
Joined Sep 2009
Apr 25, 2011 19:23 |  #5
Bryan's right - I don't know what I was thinking when I wrote that...
The Cactus V5 only allows you to trigger the attached flash - no ETTL and no beam assist.
Apr 25, 2011 23:37 |  #6
CiM_Photography wrote in post #12291940 (external link)
Ok, I got really excited there for a minute. There are a lot of pros to the Cactus v5, but I have my disappointments.
No ettl passthrough
the mode dial is very easy to change, and very hard to read
I wish there was a dedicated on/off switch, mine always gets left on and the batteries die.
But functionality is amazing with them.
Bryan
Csae
Apr 26, 2011 01:22 |  #7
I never did get the whole flash the corners to bring up the entire ambient thing...
Doesn't that show up in the shots !?!? If said corner happens to be in a frame, gotta keep all said corners out of frames, gotta make sure nobody is real close to that said corner in a frame...
I need to give this a try one of these days and see for myself i guess.
Feel free to call me Case.
CasePhoto.ca (external link) - FanPage (external link)
-Montreal based Photography.
Peacefield
Apr 26, 2011 06:52 |  #8
Thanks, guys. I think I'm going Phottix Stratos. I'm slowly working my way towards manual flash so ETTL isn't a concern, but I feel focus assist in those dark reception halls is too important to not have. It sounds as though I get that with Stratos at a fairly reasonable price.
1,961 views & 0 likes for this thread, 5 members have posted to it.
1592 guests, 137 members online
