Thread started 26 Apr 2011 (Tuesday) 09:40
It's Time To Dispell A Myth About Speedlight's And Lightboxes
TMR ­ Design
Joined Feb 2006
Apr 26, 2011 09:40 |  #1
I finally had the time to confirm and document what I've known for a while with regard to using Speedlight's with lightboxes.
This is a real Mythbuster, folks! :D
Many people ask about using softboxes with Speedlight's and a huge concern seems to be whether the softbox is too large or if it's going to eat up too much power.
Typically, the person asking the questions is dissuaded and smaller modifiers are recommended. That's a shame. The misconception is all over the internet and it's time to put an end to it! ;)
Rather than continue this guessing game I set up a small selection of modifiers ranging in size and type, and took a meter reading. The numbers speak for themselves and the bottom line is that you can pretty much use whatever size or shape modifier you want without sacrificing anything.
I took all readings with a Sekonic L-758DR mounted on a light stand in a fixed position, 6 feet from the face of the modifier, and set to meter at ISO 100. The flash is a Nikon SB-900, which I believe has a slightly lower guide number than a Canon 580EXII. Flash zoom was set to 24mm and power was at full (1/1). The flash head was rotated 90 degrees so the orientation matched that of a rectangular softbox in vertical orientation.
I went from one extreme to the other, starting with a small 16" x 22" softbox with a single layer of diffusion, all the way up to a 54" x 72" softbox with an inner and outer layer of diffusion. I also threw in a few umbrellas just for comparison.
And here are the numbers.
46" Umbrella - white satin interior - black backing - reflective bounce - f/8 + .3
46" Softlighter II - with diffusion panel - f/5.6 + .7
43" Umbrella Softbox - f/8 + .5
16" x 22" Softbox - white interior - with single layer of diffusion - f/8 + .8
24" x 32" Softbox - white interior - with inner and outer diffusion panels - f/8 + .4
36" x 48" Softbox - white interior - with inner and outer diffusion panels - f/8 + .7
54" x 72" Softbox - silver interior - with inner and outer diffusion panels - f/8 + .2
Since those are readings from the center hot spot I also went ahead and took some additional readings with the 54" x 72" softbox to see how well the light was being distributed and what the coverage was like. I found no more than -.4 EV difference from center to the short edge. It was about -.2 EV from center to long edge. Very respectable and as good as with some modifiers used with studio strobes.
I was a bit surprised by the lower reading from the Softlighter II but that does explain why I too believed that umbrellas and indirect umbrella softboes were not as efficient as enclosed lightboxes. I was also surprised to see the Cheetah 43" umbrella softbox with a higher reading than the Softlighter. 8/10 stop higher, to be exact.
You can see that going from a tiny softbox to a very large one only shows 6/10 stop difference and still gives a very high output. It's not losing multiple stops of light as many seem to think.
So, in terms of output, battery life and recycle time, it's really all the same with very little difference and no reason to worry about modifier size unless your flash does not allow for wide angle zoom settings such as 24mm. I didn't go crazy changing the zoom setting but I'm sure that you can optimize things by doing tests to see which zoom setting is best for each size modifier. I figured this would be a good general reference.
Robert
lens ­ pirate
Apr 26, 2011 10:01 |  #2
Man.... Its so cool when common knowledge is turned on its big fat head.
great work.... I hope you cross post this to lots of forums...
INSANE GEAR LIST
Sun flare.... the new selective color. JUST SAY NO
suecassidy
Apr 26, 2011 10:05 |  #3
thanks for that! great work, myth buster!
Sue Cassidy
GEAR: Canon 1ds, Canon 1d Mark iii, Sony RX 100, Canon 50mmL 1.2, Canon 70-200L 2.8 IS, Canon 100-400L IS, Canon 14mm L, 2.8, . Lighting: Elinchrom Rangers, D-lite 400s, Canon 580/550 flashes. 74 ' Octabank, 27' Rotalux. Editing: Aperture 3
m.shalaby
Apr 26, 2011 10:07 as a reply to  @ suecassidy's post |  #4
awsome info!!!!
I'm now going to use a hot air balloon as my next light modifier! :cool: :p
BrandonSi
Nevermind.. I'm silly.
Gallery: 62 photos
Joined Sep 2004
Apr 26, 2011 10:20 |  #5
f/8 isn't bad.. what as that, like 5 feet distance between modifier / meter?
Light theory can confuse me at times, but reducing the flash power should only reduce the light output, not the coverage, correct?
[ www (external link)ยท flickr (external link)]
huntersdad
Apr 26, 2011 10:26 as a reply to  @ m.shalaby's post |  #6
Not being the most astute person when it comes to flashes, someone explain the bolded numbers for me. I assume f/XXXX would be aperture, but what's the second one telling you?
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
TMR ­ Design
Joined Feb 2006
Apr 26, 2011 10:26 as a reply to  @ BrandonSi's post |  #7
Hi Brandon,
My bad. I just edited the post and added that the meter was 6 feet from the face of the modifier.
Robert
Lichtwerk
Apr 26, 2011 10:28 |  #8
huntersdad wrote in post #12295573 (external link)
f/8 + .3 would be f8 and 3/10ths of a stop.
And as usual, great post Rob :)
Dennis
Grip Aficionado
500px (external link)
huntersdad
Apr 26, 2011 10:33 |  #9
Lichtwerk wrote in post #12295583 (external link)
Is the 3/10 aperture or additional light related? For example, since his one is easy for me, 46" Softlighter II is f/5.6+.7. Are we saying that it is measuring roughly f/7.1 or am I missing the point of what we are measuring here?
Got to learn sometime.
professoryeti
Apr 26, 2011 10:36 |  #10
huntersdad wrote in post #12295607 (external link)
No, that's right. It's measuring very close to f/7.1
Saturnalia for all you have.
5D Mark II | 5D | 24mm f/1.4L II | 35mm f/1.4L | Nikkor 50mm f/1.2 | Canon 100mm f/2.8L | 24-105mm f/4L | 70-200mm f/2.8L IS II |
JoshNibertPhotography.​com (external link)
huntersdad
Apr 26, 2011 10:38 as a reply to  @ professoryeti's post |  #11
And that would provide correct exposure based on the lighting conditions and distances provided?
professoryeti
Apr 26, 2011 10:39 |  #12
Yeah, according to the meter the "correct" exposure for an SB900 at 1/1 power in that modifier with a subject distance of 6' is f/7.1
Lichtwerk
Apr 26, 2011 10:40 |  #13
As professoryeti said, that's correct. I take it you don't have a lightmeter. Most of them display in-between stops in 10ths of an f-stop.
Dennis
Grip Aficionado
Mark1
Apr 26, 2011 10:41 |  #14
Its all true. Seems to be counter intuitive, but still true. I will use a speedlight in a 70 inch octo with out a bit of hesitation if I only need a little bit of soft light or if I am wanting to shoot wide open.
TMR ­ Design
Joined Feb 2006
Apr 26, 2011 10:42 as a reply to  @ huntersdad's post |  #15
The metered exposure values would be the correct exposure using those settings and with the subject 6 feet from the light source.
A quick guide:
A reading of f/8 + .3 means the whole stop f/8 plus 3/10 stop. 3/10 stop is the same as 1/3 stop. .7 is 7/10 or 2/3 stop.
f/8 plus 1/3 is f/9. f/8 plus 2/3 is f/10, and so on..
Robert
38,785 views & 0 likes for this thread, 47 members have posted to it.
1608 guests, 142 members online
