Thread started 26 Apr 2011 (Tuesday) 12:03
How to check light meter kenko 1100
ukcyberboy
Apr 26, 2011 12:03 |  #1
I am just asking as I am not sure my pictures are correct.
I tried a light test with the sunny 16 rule ie ss 100 iso 100 and f/16.
Any help or test I can using a flash and what I should be looking for on the histograph.
I have some pics that I can post.
Body | Canon 6D |
Lens | Yongnuo 50mm 1.8 |
Lens | Canon 28-70 2.8 L |
Lens | Canon 70-200is F4 L |
Lighting | Yongnuo YN600RX |
Accessories | Various Bits |​
Wilt
Apr 27, 2011 00:05 |  #2
If you do not have access to a second meter to compare against, here is the only thing I can think of to try to compare...
a. Get an 18% gray card, meter it with Spot mode in your camera meter, shoot a photo of that card. That becomes your 'proper exposure' density to compare against the next step.
b. Meter the flash with your Kenko, take a flash photo of the 18% gray card at that indicated combination of aperture and shutter speed.
c. Compare density of shot A with density of shot B...they should be fairly similar.
BTW, I have found that my own 40D spot meters the 18% gray card at the same light reading as obtained with my Minolta Autometer Vf in incident mode (that same meter later began to be marketed by Kenko)
PhotosGuy
Moderator
Joined Feb 2004
Apr 27, 2011 10:59 |  #3
Or you can try my 1-cent flash "meter" in images 5S & 6S.
Simple 2 Light Portrait Set-up
ukcyberboy
Apr 27, 2011 13:40 as a reply to  @ PhotosGuy's post |  #4
Thanks I will try that.
Body | Canon 6D |
Wilt
Apr 27, 2011 14:03 |  #5
I just ran the test which I suggested. Ambient ISO 400 metered 1/10 f/4, flash metered ISO 400 1/200 f/11 (flash Manual). A part of each frame, and the corresponding histograms, with no adjustment to RAW other than for White Brightness setting.
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/Ambientmetered.jpg
Ambient
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/Flashf11metered.jpg
Flash
Proves the test works!
ukcyberboy
Apr 27, 2011 14:57 as a reply to  @ Wilt's post |  #6
I will give this ago thanks very much.
Body | Canon 6D |
2,292 views & 0 likes for this thread
Latest registered member is Piet ZA
3371 guests, 350 members online
