Thread started 26 Apr 2011 (Tuesday) 14:24
Where's a good place to go to learn the basics?
jrm27
Apr 26, 2011 14:24 |  #1
Hello all,
I just finished order a t2i from the canon loyalty program (pumped) and am excited about exploring the world of digital video. Is there anywhere that I should go to learn the basics? Things such as framerate, what the ideal shutter speeds are, etc..?
I've also purchased a zoom h1, so I'm going to explore using secondary audio sources as well.
One of my main concerns is that currently I shoot full manual on my 5D and do a lot of work in post to my RAW images. I do things like setting white balance, correcting exposure issues, etc.. I'm assuming that I'm not abel to do these kind of edits with video. Is that correct? Is there a way to "edit" raw video per-se? I'l also be using Adobe Premier Pro for my video editing once it is ready to go.
Anyways, any direction to a helpful repository of information for a video noob would be most appreciated!
http://www.flickr.com/​photos/jrmelot/ (external link)
Chippy569
Apr 26, 2011 14:31 |  #2
premiere (with the e) can do white balance (it's called "color correction" in video) and other editing, just like in photoshop. Here's everything you need to know about settings:
Shutter speed: 1/2r, where r = your frame rate.
Aperture: as open as you need to get the desired depth of field
ISO: Adjusted to get proper exposure.
Frame rate: for a "cinematic look" stick to 24fps. If you need to do anything in "slow motion" then use a higher frame rate so there is more info to be slowed down to. 30fps is standard for TV and other broadcast media.
David Nichols (external link) - Sound Designer
How to export to Youtube HD from Quicktime
jrm27
Apr 26, 2011 14:52 |  #3
Thank you David. The information is very much appreciated!
Chippy569
Apr 26, 2011 15:02 |  #4
if there's anything you need to learn how to do in premiere, you can always go to youtube and search.
jrm27
Apr 26, 2011 15:12 |  #5
agreed. That's what I've been doing with other projects I've been exploring. Between there and here, I've learned a ton.
Here's a question though. I've been reading that the t2i has a 12 minute recording limit. Is there any way to bypass that (magic lantern or something similar?)?
Chippy569
Apr 26, 2011 16:09 |  #6
not 100% certain if ML can or not, but unless you're trying to broadcast you really should have no problem staying below that. Turn record on, ask question, get answer, turn record off, next question.
jrm27
Apr 26, 2011 17:54 |  #7
That's what I had figured. I was just trying to think forward to situations where I might want to video a sermon or something.
BlueCadet3
Joined Jun 2010
Apr 28, 2011 00:31 |  #8
jrm27 wrote in post #12298265 (external link)
Well, for a situation like that, you might want to get like a CCD camcorder.
The T2i's CMOS sensor tends to get hot, and even sometimes overheat.
It's more for clips that you would compile together in post.
a n d r e w|c i o b a n a s i u
g e a r|m e (external link)
1,047 views & 0 likes for this thread, 3 members have posted to it.
1206 guests, 123 members online
