Thread started 27 Apr 2011 (Wednesday) 14:48
monopod for 70-200mk2
0.0f
Joined Apr 2011
Apr 27, 2011 14:48 |  #1
hi everyone
im looking to get a nice light weight monopod for my 70-200. want something which is quick to put into action and easy to move around.
EOS 5D MK3 - 24-70 MK2
simonjs
Apr 27, 2011 15:51 |  #2
I use the Gitzo GM2541 monopod.
wookiee2cu
Apr 27, 2011 16:10 |  #3
I've got one of these manfrottos: http://www.bhphotovide​o.com …eoTec_Monopod_D​eluxe.html (external link)
It's nice because there are no screws, knobs or levers to tighten and you can do everything with 1 hand. It weighs 1.76 lbs and supports 17.6 lbs. I also got a manfrotto 234RC tilt/swivel quick release: http://www.bhphotovide​o.com …Swivel_Tilt_Hea​d_for.html (external link) This way I can get the camera on and off quickly.
yourdoinitwrong
Apr 27, 2011 16:47 as a reply to  @ wookiee2cu's post |  #4
I use a Manfrotto 679B. It's lightweight and inexpensive (less than $50) and will support plenty of weight, depending on the head you put on it.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
RPCrowe
Joined Nov 2005
Apr 27, 2011 19:15 as a reply to  @ yourdoinitwrong's post |  #5
I used a Manfrotto 681B for years and was quite satisfied with all the parameters of this pod... except for the size when folded. It was too big to put in my check-on airlines bag and airlines mostly will not allow you to carry a monopod aboard the flight because it is considered as a "weaponlike instrument" I had the choice of getting a new suitcase, a new monopod or simply traveling without the pod.
The 681B can easily support a 400mm f/5.6L lens on a Manfrotto Gimbal mount and could certainly support your 70-200mm Mk-ii.
I decided that I wanted a monopod on my trip to China last year and that it would be less expensive to sell the 681B and buy a new monopod than to buy a new suitcase.
I now use a Calumet 8103 4-section Carbon Fiber Monopod which I bought new (on-sale) at my local Calumet store in Escondido, CA. It is equipped with a Kirk MPA-1 Arca Compatible Swivel Head which allows me to take advantage of all my Arca Compatible camera and lens plates, including my RRS L-plates.
The Calumet has about the same capacity as the 681B, folds shorter and weighs a bit less. However, it is about twice as expensive. I do consider it money well spent. I like the calumet twist locks over the flip locks of the Manfrotto because I can carry the pod in a belt loop more easily. The pod also comes with a Calumet carrying bag but, when the MPA-1 is installed, the bag cannot be zipped close.
Savas ­ K
Apr 27, 2011 19:52 |  #6
I'm using a Gitz 5561T. Folds to 16 inches, extends to 62, holds 55 pounds, weighs a pound and a half. You can pole vault with this thing and it won't collapse.
1,168 views & 0 likes for this thread
Latest registered member is Jesterj75
789 guests, 164 members online
