Xcelx wrote in post #12307837
The hood is made for 100mm on FF, not big enough at 400mm on a crop. The point is I often have to shade the lens with my hand or something else when shooting close to the sun at 400mm. Oh well I guess I'll just have to try it out and start out big and just make it shorter until it's perfect.
Experiment with an extension made of black construction paper and masking tape. This is extremely simple and inexpensive.
You could even make a petal-shaped extension if the place where the original hood attaches does not rotate with either focal length change or focus change.
Once you've established the optimum shape, then you can create a permanent solution. I don't recommend using wood, though. I would make something that is collapsible (able to fold flat) and could be applied when needed. By being collapsible, it will store more easily in your camera bag.
