Thread started 27 Apr 2011 (Wednesday) 18:58
Speedlite Guru's - HSS & dark half of frame/synce issues ??
m.shalaby
Apr 27, 2011 18:58 |  #1
Body: 5dmkii
Flash: 430EXII
I have the flash set on HSS, and while im in ETTL mode, I can shoot all the way up to 1/8000 shutter speed with no sync issues.
BUT - As soon as I put the flash in Manual mode, and shoot anything above 1/250 I get a dark bottom of the frame. (mind you, the flash is still in HSS mode).
I thought that as long as you kept the flash in HSS mode, you could go ETTL or Manual without sync issues.
I tried manual zoom on the Speedlight and Auto - still having the same issue....
Is this normal?
windpig
Chopped liver
Apr 27, 2011 19:07 |  #2
I just popped two flashes with my 5DII, 580EXII in the hot shoe. No problem at 1/800 in both manual flash and ETTl. Manual Camera settings.
Go ahead, spin the wheel.
s2kennyc
Apr 27, 2011 19:09 |  #3
What are you using to trigger your flash?
-Ken
windpig
Chopped liver
Apr 27, 2011 19:25 |  #4
s2kennyc wrote in post #12305736 (external link)
Good point to bring up, I assumed he would be shooting with an ETTL cable or in the hot shoe.
Even the 7D flash commander won't do HSS.
m.shalaby
Apr 27, 2011 19:33 as a reply to  @ windpig's post |  #5
this was attached to the hot shoe of the camera.
i'm experiencing very weird issues.
what I described above happened, having the camera in AV mode.
I put the camera in M mode and set all the settings the same as they were in AV and when in M mode, no more sync issue.
so i said hmmm.... let me put it back into AV mode and see what happens.
issue gone. now it works fine.
so just by simply changing the camera from Av to M back to Av took care of the issue...
electronics - can't live with em', cant live without em'.
windpig
Chopped liver
Apr 27, 2011 19:37 |  #6
Glad it resolved itself.
BTW, your Strangers Project photographs are great.
m.shalaby
Apr 27, 2011 19:39 as a reply to  @ windpig's post |  #7
^ thanks.
Now I'm trying everything with my pocketwizards (MiniTT1 & FlexTT5) and everything is working perfectly
except
on the very bottom of the frame, there is an ever so slight dark cut off.... very slight, only a wisper, but its in every shot I take....
anyone know what i need to do in the Pocket Wizard Utility to fix this?
Methodical
Gallery: 239 photos
Apr 27, 2011 19:52 |  #8
Is this at the 1/200 sync speed?
I have a similar problem with my RF602s. 1/200 and I get a slight dark line at the bottom of the image, but at 1/160th no problem - all this when zoomed at 24mm. I recall reading in here that some had issues and some did not.
m.shalaby wrote in post #12305954 (external link)
^ thanks.
except
Gear
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
m.shalaby
Apr 27, 2011 19:56 as a reply to  @ Methodical's post |  #9
^ i'm getting this at basically all SS
Methodical
Gallery: 239 photos
Apr 27, 2011 20:50 |  #10
Oh.
I read somewhere on here that may happen if the batteries are not up to speed (trigger batteries).
Anyway, here's an article on the 5D2 and sync speed at strobist site. One responder talks about having sync issues with the pocket wizard. It might help some. Based on this article, I have a slow sync camera, but I don't recall having an issue with the flash on the camera, so I chalk it up to the 602s. Keep the thread updated with you results. Also, just in case, check the sync speed custom function to make sure it's in auto.
http://strobist.blogsp​ot.com/2010/01/know-your-sync.html (external link)
Here's another thread: https://photography-on-the.net …light=5d+mk+ii+​sync+speed
m.shalaby wrote in post #12306042 (external link)
Gear
Ron ­ Hu
Apr 28, 2011 20:35 as a reply to  @ Methodical's post |  #11
Update to the latest PW utility. 1.35 I think it was.
Are you using the beta firmware for both the mini(if ya have one) and the Flex?
Grab the beta F/W for both. You might have to adjust the offset on syncing the shutter with the HSS option.
Canon EOS R5,
Tamron SP 24-70 DI VC G2, Canon EF 70-200L MK II
Sigma Art 14mm, 35mm 85mm, PW Mini TT1 & 4x Flex TT5, 580 Ex II & 430 Ex II, 4x AB800, 4x AC9, PCB BD and Soft box for AB; Sekonic 478DR
bdp23
Apr 28, 2011 20:50 |  #12
Darkness at the bottom of the frame suggests the flash is going off too soon, or the first curtain is running slow (for speeds slower than 1/200th).
That it's happening with the pocket wizards I'm surprised because if anything they should increase latency and be cut off by the second curtain (darker at the top as the second curtain is shading the sensor while the flash pops)
Could you have a sticky shutter???
I like making photos and sometimes I think I'm getting better... then I realise it doesn't matter. I like making photos!
m.shalaby
Apr 28, 2011 21:35 as a reply to  @ bdp23's post |  #13
^ i got the issue fixed guys, but thanks.
Methodical
Gallery: 239 photos
Apr 29, 2011 12:52 |  #14
What was the problem?
m.shalaby wrote in post #12313625 (external link)
Gear
m.shalaby
Apr 29, 2011 13:11 as a reply to  @ Methodical's post |  #15
No idea.... i threw the camera into M mode, then back into AV mode and it all of the sudden worked fine.
weird.
2,586 views & 0 likes for this thread, 6 members have posted to it.
2744 guests, 165 members online
